1 Wall...3 Rooms - Painting - DIY Chatroom Home Improvement Forum
Old 01-12-2013, 07:38 AM   #1
1 wall...3 rooms
Ok it's really 2 rooms and a hallway leading to the bedrooms! My question is....do I have to paint the entire wall 1 color or is there a way to break it up? There is curre t,y no molding or anything else breaking it up...don't really want the same color running from dining room, thru kitchen and then down hallway if I don't have to but I'm really not sure how to start and stop color!
debnvince is offline   Reply With Quote
Old 01-12-2013, 07:49 AM   #2
Rewards Points: 13,748
Got a picture?
debnvince (01-12-2013)
Old 01-12-2013, 07:54 AM   #3
Rubbin walls since'79
Brushjockey's Avatar
The architecture can make color changes difficult. Somtimes the best solution is really to have a single color- if the areas flow together it might look very patchworky to have them each a different color.
That said- it might be possible, and Joe asking for a pic would be good, its hard to say without seeing.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Old 01-12-2013, 08:09 AM   #4
I saw a pic once of a fully open floor plan loft. They cut a straight line down the middle of one long wall and did a blue/white type color contrast. On the light side was the kitchen area and on the darker side was the living room area. It perfectly highlighted the two separate areas and was very dramatic. Sometimes the things you least think would look right look best. It's only paint, we're not tearing out walls, except for Joecaption, take a chance.
The Following User Says Thank You to jsheridan For This Useful Post:
Old 01-12-2013, 08:18 AM   #5
Originally Posted by joecaption
Got a picture?
I can take a picture but I don't know how to post it....I'll try to figure it out!
Old 01-12-2013, 08:53 AM   #6
I hope this works!
Old 01-12-2013, 09:53 AM   #7
That does help.
The arches have hard corners, so that is there it would change. Usually I advise people to decide which is the dominate room (like the hall would be, into a room, and paint the interior of the arch with the dominate area color.
I would say that what looks like kitchen to Living room looks very open, and I would do those the same color so it isn't all broken up. you can change sheens ( might want eggshell in kit- matte in LR for instance- but keep color consistent.
JMO..
Old 01-12-2013, 10:41 AM   #8
Originally Posted by Brushjockey
That does help.
JMO..
Well thank you very much....that helps a lot! And I never thought of changing the sheen! I bet that really makes an impact when it's right next to each other! So you wouldn't suggest any type of vertical molding to break up the area then? Not that I wanted to do that but I thought it might be the thing to do!
Old 01-12-2013, 10:43 AM   #9
That does help.
JMO..
I also wanted to say that from the pictures it looks like its already different colors but that's just the lighting!
Old 01-12-2013, 10:56 AM   #10
I cant even picture where you would want to do this. In the middle of an arch?
No- making fake dividers looks just like what it is.
The outside corners of the arch is the spot. The only question is which side to change. And like I said, look at the flow- a room is less dominate than a common area like a hall - so bring the hall color through the arch and that corner of the arch is where it changes.
Old 01-12-2013, 11:07 AM   #11
Thanks again!!!
Old 01-12-2013, 04:56 PM   #12
Deb, I thought you were asking how to avoid painting that long wall that goes down the hall, past the kitchen and into the dining area? I'm not following here, but that doesn't really matter.
Old 01-12-2013, 05:11 PM   #13
No I want to paint the entire thing but I wanted yellow in the kitchen but not necessarily the hall...I don't know...I'm open to all suggestions!
Old 01-12-2013, 06:06 PM   #14
I see. A good rule of thumb for which color an arch interior gets is what floor is under it. When two floor types meet under an arch, one will dominate and the room over that floor determines the color of the interior arch. However, I see that you have hardwoods throughout. I would suggest, as I think Brushjockey said, the interior arches should get the color of the largest area, which would be the color of the hall. This way the wall in the pic with the clock would be framed by the color of the hall wall, which would highlight that clock wall color. I think the other way would out of rhyme, out of kilter.
Retaining wall work-- what approach? emcelvaney Landscaping & Lawn Care 2 09-24-2012 07:49 PM
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 06:42 PM
Avoiding load on inner, exterior wall jklingel Building & Construction 2 06-04-2011 01:35 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
