1 Month Old Paint Peels Off Easily - Painting - DIY Chatroom Home Improvement Forum
Old 01-17-2012, 08:46 AM   #1
1 month old paint peels off easily
My contractor removed a door frame and patched up the paint a month ago. Now there are multiple cracks on the patch and the paint peels off easily - I used the blue painter's tape to tape a plastic tarp on it and when I removed the tape the paint comes with it.
My contractor didn't use primer and paint directly to the drywall/compound and I think it is the origin of this problem. My contractor is not answering my phone any more. I am going to make a complaint against him. But what is my option right now. The ultimate thing to do might be to scrap off all his junk and then prime and then put on paint. But is it a must? Can I start on the current paint?
htabbas is offline   Reply With Quote
Old 01-17-2012, 03:36 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 606
What id your'e specific question?
Old 01-17-2012, 04:33 PM   #3
Mr. Paint's Avatar
Your paint on the drywall has bee3n disrupted and is subject to peeling with a little tape removal? Is it peeling to another coat of paint or is it peeling directly to the drywall? Is it peeling to the drywall face paper or a skim-coat of wallboard compound? How extensive is the peeling? Your answers here will help us point you in the right direction.
Mr. Paint is offline   Reply With Quote
Old 01-17-2012, 05:00 PM   #4
A Little Of Everything
Rewards Points: 1,364
That IS the origin of the problem.
I'm not sure exactly what you're describing or asking, but you cannot paint drywall without first priming it. Get all of the "paint over unprimed drywall" off. Prime the whole wall. Paint it.
DrHicks is offline   Reply With Quote
Old 01-17-2012, 05:52 PM   #5
"The ultimate thing to do might be to scrap off all his junk and then prime and then put on paint. But is it a must? Can I start on the current paint? "
This was my specific question. But it seems that I have to scrap off the original layer of paint and then start all over again.
Old 01-17-2012, 09:13 PM   #6
Matthewt1970's Avatar
Rewards Points: 1,098
Didn't we just have an "expert" try and educate us recently in here that you don't need primer?????
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
chrisn (01-18-2012)
Old 01-17-2012, 11:01 PM   #7
Learning Things Every Day
Jay 78's Avatar
Of course not. He'd have to be in your house to answer your phone.
Yes. Do it right - by undoing the mistakes already made - or your work will suffer the same fate. Preparation is key. You've seen what happens when corners are cut.
Under Construction
Jay 78 is offline   Reply With Quote
Old 01-18-2012, 10:01 AM   #8
ARC Painting's Avatar
Painting over a problem never makes it go away, unfortunately.
Another tip: If you paint over loose drywall dust paint won't stick. Always vacuum and/or wipe the dust away.
Toronto Painters, House Painting
Facebook: ARC Painting Toronto
ARC Painting is offline   Reply With Quote
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
Painting Old House Smokin Gun Painting 36 07-05-2011 01:24 AM
new trim paint peels when scuffed, hit, etc. jamyb Painting 2 09-12-2010 11:10 PM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
