I tend to add 40 percent or so of the paint color formula mix to primer when covering dark colors or planning to add one.
Usually, I just use one coat of primer but I remember painting over a goth teen all black room once. It made more sense to do two coats of primer than spending the money on an extra finish coat layer. Primer is cheaper.
Yes, you should be able to cover it with one primer. However, in some cases you will need two. I had a dark blue paint in my dining room that I wanted to paint over with yellow paint. My Arlington Heights home improvement contractors used two coats of primer. Otherwise, the blue would've shown through to the yellow! Your rose color should be okay with one, but I recommend to other people that it just depends on the situation.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
