Old 07-09-2009, 10:29 AM   #1
Is 1 coat enough?
Hi everyone, I just applied one coat of BM Super Spec Primer over blue Humitek Drywall in my bathroom. I would say 95% of is covered and the other 5% you can see some blue showing through. Do I need to buy another gallon and put a second coat on - or is one coat enough?
Cheers,
Jason
moosejohnson is offline   Reply With Quote
Old 07-09-2009, 10:49 AM   #2
NAV
Is 1 coat enough?
one is enough. the blue you painted over isn't going to bleed through your finish coat. the only reason to prime over dark colors is because the primer is cheaper than the top coat and it will save you money.
I use 2 finish coats on all of my interior walls - even same color over same color. it's rare for a dark color to take 3 coats of anything if you know how to paint.
NAV is offline   Reply With Quote
Cracks in stucco scratch coat - is this normal? chadurban Building & Construction 5 05-25-2009 11:55 PM
do I have to sand my first coat of semi-gloss on ceilingbefore I apply the 2nd coat? newbpainter Painting 6 04-07-2009 10:01 PM
Can you put brown coat on if it's going to rain? Not Sure Building & Construction 3 03-23-2009 07:57 AM
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 07:23 PM
Round 2 & 2nd coat question usaalways Painting 5 06-24-2007 09:20 AM
