Who To Call For Sliding Glass Door Repair - Off Topic - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 05-17-2010, 07:42 PM   #1
Who to call for sliding glass door repair
Hi, my husband and I are having a problem with a sliding glass door, purchased from Sears in about 1991 or 1992. The problem is that the steel support has separated from the interior wood door. The door won't close unless wedged.
We have no idea how to fix this, but here's the real problem: who do we call to fix it? The obvious answer might be Sears, but based on past experiences, it will not only be costly but may not be fixed properly.
The area of repair doesn't seem to fall under the category of carpentry, yet we don't know what kind of specialty it would be.
I'd really appreciate any help you can offer.
Jane1976 is offline   Reply With Quote
Old 05-18-2010, 06:51 AM   #2
This is a Do It Yourself website, not a referral site, but i would guess that the rollers at the bottom have failed. Not sure what metal you refer to.
Check friends, neighbors, etc, for references for a good handyman or contractor.
Old 05-18-2010, 08:40 AM   #3
This could be a tough item to fix depending on how broken things are. Parts could be tough to find if they are needed too.
Is this an interior sliding door or does go directly outside?
How is the rest of the door holding up?
It might be more beneficial in the long run to just get a new sliding door. Thats probably the route I'd go. You're talking about an almost 20 year old door that probably gets opened and closed a lot.
D-2.5-GT is offline   Reply With Quote
Tags
sliding glass door
Glass on greenhouse roof Flavio Building & Construction 16 07-15-2010 08:37 AM
"Defogging" double-pane windows .... a gimmick?? alexz General DIY Discussions 133 03-10-2010 01:35 PM
Impact Windows & French Doors Matty16 Carpentry 6 06-22-2009 10:01 PM
Help with replacing some glass shonkster Building & Construction 5 03-12-2009 06:24 PM
