What's The Worst Thing You've Found After Midnight? - Off Topic - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 04-10-2011, 12:12 PM   #1
Learning by Doing
Leah Frances's Avatar
What's the worst thing you've found after midnight?
Last night, when I headed to bed, I discovered that the supply line for my toilet was leaking at the compression fitting. I, of course, discovered this by stepping into the lake of water in my bathroom. This is pretty bush league, as all I had to do last night was towel off the floor and turn off the shut-off.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 04-10-2011, 12:28 PM   #2
kwikfishron's Avatar
Rewards Points: 576
Kind of hard to beat Ants loosening the compression fitting for the toilet and flooding the bathroom.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Leah Frances (04-10-2011)
Old 04-10-2011, 12:30 PM   #3
Learning by Doing
You think it was the ANTS???? Now I must DESTROY THEM!!!!
Old 04-10-2011, 12:47 PM   #4
the Musigician
DangerMouse's Avatar
Yup, once those little ******** are on the loose, there's no limit to the amount of damage you can blame on them.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
Old 04-10-2011, 12:52 PM   #5
One night, we had settled into bed after turning on the dishwasher. When the dishwasher cycle hit discharge, the air gap on the sink blew apart and pressurized water was hitting the ceiling. Major wakeup! Art
ArtBraendel is offline   Reply With Quote
The Following 2 Users Say Thank You to ArtBraendel For This Useful Post:
gmaint (10-07-2014), Leah Frances (04-10-2011)
Old 04-10-2011, 03:47 PM   #6
Tizzer's Avatar
Rewards Points: 460
Probably would be the time I had to use the bathroom and the cat had pooped on the bathroom carpet instead of her litter box.
Tizzer is offline   Reply With Quote
Old 04-10-2011, 03:53 PM   #7
Remodeler
Rewards Points: 324
The draft inducer motor on my furnace started howling and burnt up in the middle of the night. Oh did I mention it was -16 degrees that night and the wind was blowing about 30 mph! We only had one little electric heater. Luckily I had saved the old inducer fan and motor from the last replacement, I coaxed it back to life with some lube and it got us by a couple days.
One night years ago I woke up at 2 am the house was cold and had a faint smell of gas. I found that freezing rain had completely covered my gas meter. The vent on the regulator was all iced over and the gas pressure had went up high enough that the pilot light on the furnace blew out. I figured it out when I lit a burner on the gas stove and the flame was about 3 times the size it should have been! There I was outside in the cold and rain at 3 am trying to melt the ice with a heat gun. Melted it off and covered it up and everything was back to normal.
iamrfixit is offline   Reply With Quote
Old 04-10-2011, 05:40 PM   #8
MY WET Toothbrush--My mother-in-law had been using it
Giles is offline   Reply With Quote
Old 04-10-2011, 08:47 PM   #9
Pretending to be Retired
My Black Lab, Licorice, needed to go outside to do his business. When I let him back inside I found out he tried to make friends with a skunk. He was so proud of himself with that new perfume smell he was sporting.
BigD9 is offline   Reply With Quote
Old 04-10-2011, 09:24 PM   #10
Old School
Willie T's Avatar
Sick babies and pets throwing up and/or choking. Big trees falling across the lawn during a hurricane... but luckily not on the house.
Willie T
Old 04-10-2011, 09:48 PM   #11
Rewards Points: 576
Tornado Siren and a hangover.
Well I guess I didn’t find it, it found me.
Old 04-10-2011, 11:18 PM   #12
just a tool guy
mickey cassiba's Avatar
Pissed off baby possum hangin' from a track light rall in the bedroom...'bout face high. No idea how it got in...took some time to catch it...little dog wanted to play!
Mickey
One of these hammers will fix it.
mickey cassiba is offline   Reply With Quote
Old 04-11-2011, 11:47 AM   #13
timmymcg's Avatar
Send a message via Skype™ to timmymcg
There was the time the baby woke me up at 2:00 and I went through the kitchen where the dog was to get something (I can't even remember what) in the living room in the course of getting him back to sleep. On the way back through the ktichen--I swear to you I hadn't been through more than fifteen seconds earlier--I didn't bother turning the light on, so I discovered that in that fifteen seconds the dog had peed on the linoleum. Which discovery I made by slipping on said piss. However, this apartment was small enough that there was no place in which a 5'11" adult could fall flat-out to the floor, so I didn't hit my head or anything. No, I managed to land on the corner of the countertop--on my bottom front right rib. YEEEOWCH. It throbs just thinking about it.
timmymcg is offline   Reply With Quote
Old 04-11-2011, 06:55 PM   #14
Handyman
Rewards Points: 512
Wow Willie...you change the batteries in your Co detector lately?? or was this a planned thing?
canadaclub is offline   Reply With Quote
Old 04-12-2011, 01:10 PM   #15
after a late ending party at my place.After everyone had left i found the woman who resembled jack black naked in my bed grinning like that chucky character in the horror movies.a sewage backup in the basement would have been more pleasant and much less ackward.
bluejeans is offline   Reply With Quote
The Following User Says Thank You to bluejeans For This Useful Post:
operagost (04-18-2011)
things found in your walls gregdonovan Off Topic 26 08-06-2011 01:20 PM
Pulled up carpet to put in wood flooring and found 2' plumbing hole in slab. Nightsky Plumbing 1 07-04-2009 07:44 AM
Can anyone tell me what is this I found in my basement? bayin Plumbing 5 05-07-2009 09:35 PM
found an old foundation crack in block floor to ceiling flashme18 Building & Construction 14 11-11-2008 09:15 PM
lost power to 1 thing in 4 different places... ManMythLegend Electrical 31 12-19-2007 12:57 PM
