What Would You Do To The Guy Who Does This? - Off Topic - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 04-07-2010, 09:37 PM   #1
What would you do to the guy who does this?
Best idea of punishment gets $500. Obviously he didn't know what he was doing, but then again why notches are perfect cut?
lm555 is offline   Reply With Quote
Old 04-07-2010, 09:40 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
what was he doing?
and form of punishment?
making him pay for the repairs.
Old 04-07-2010, 09:43 PM   #3
Learning by Doing
Leah Frances's Avatar
Hung by the neck but still living, have the guts removed and burned before the still living eyes, remove the head and split the body into four pieces to be located where ever the sovereign deigns fit.
Ooops. That was at 16th cent punishment for treason.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 04-07-2010, 09:46 PM   #4
nap
You talking to me?
nap's Avatar
have you ever seen that neat little "tool" where they would slit the belly open, grab the intestines and attach to this little crank thing and slowly wind the intestines onto the spindle while the person got to lay there and watch?
Old 04-07-2010, 10:08 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 400
Is this somethig recently done?
How many are like that?
jbfan is online now   Reply With Quote
Old 04-07-2010, 10:23 PM   #6
nap
You talking to me?
nap's Avatar
looks pretty fresh to me.
Old 04-08-2010, 08:51 AM   #7
Rewards Points: 150
Why was that done?
slickgt1 is offline   Reply With Quote
Old 04-08-2010, 10:28 AM   #8
remodeling pro
Get to the punative punishment later, but now, hopefully the culprit is still around working on the house, and you owe him some money. These joists need to be string lined from plate to plate and jacked until the are straight again, then sistered. Full width plate to plate if possible, if not, as long as posible, and bolted together with 1/2" bolts. I agree, the notches look fairly fresh, but the joist directly in front of the drain pipe already has a clearly visible sag in it. The water stains on the joists lead me to surmise that there is a bathroom above, making a plumber the most probable culprit.
As for punishment, I suggest the old method farmers used to use to castrate hogs. A wire just like rebar ties was twisted around the testicles, cutting off blood supply, and they just died and fell off.
troubleseeker is offline   Reply With Quote
Old 04-08-2010, 10:38 AM   #9
Since there doesn't seem to be a question on DIY I'm moving this to Off topic
Old 04-08-2010, 12:08 PM   #10
Rewards Points: 150
Cut equal sized notches in his legs and see how much they like it. Would probably be just as instable as the notched joists....
TJ_in_IL is offline   Reply With Quote
Old 04-08-2010, 04:15 PM   #11
Rewards Points: 5,336
So very neat, yet soooo... very wrong.
Ron
Old 04-08-2010, 04:49 PM   #12
the Musigician
DangerMouse's Avatar
It's 1313 Mockingbird lane....
GrandPa cut those so Herman wouldn't hit his head in the lab....
...quite as much....
DM
Old 04-09-2010, 06:47 AM   #13
Man of many hats
wrangler's Avatar
Rewards Points: 354
Looking at the holes that had already been drilled and the pipes that are hanging below the joists to the left, I'm betting someone was going to relocate the those pipes to install a ceiling when their drill bit got dull or ran out of clearance and opted to just notch the joists instead. Probably just took a circular saw set at 1 1/2", made two perpendicular cuts and whacked the notch out with a hammer. I'd do as suggested above and get them repaired before they sag further.
Man of many hats
wrangler is offline   Reply With Quote
Old 04-09-2010, 07:37 AM   #14
Military Mom of 4
Snav's Avatar
Hey! Look on the bright side of things. At least he didn't just cut all the way through it without giving any alternative means of support like someone did in my bathroom:
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 04-18-2010, 10:44 AM   #15
Sherpa's Avatar
Anyone caught doing this, or the OP's job should be encased in poured concrete - while still alive!
Sherpa is offline   Reply With Quote
