Go Back   DIY Chatroom - DIY Home Improvement Forum > Community > Off Topic
Old 11-03-2009, 05:05 PM   #16
nap
You talking to me?
nap's Avatar
"what does that button do?"
Maintenance 6;348765]You quoted one line out my original post and then told me I was incorrect. I only tried to clarify my original post. I stand by my original statement. A dry pre-action sprinkler system will not flow water just by the activation of a sprinkler head, either by accident or in a fire situation. A specific chain of events is required.
I';; accept that. While you do understand and actually use the proper terminology of "pre-action" and dry systems, I was mixing the two together. A pre-action as well as an air over water system are often called generically; dry systems, when in fact, neither technically is. They are more properly called "dry pipe" systems while a gaseous system would more properly be called a dry type system.
simply semantics.
I understand and agree with your facts.
The point is that just because you see a sprinkler head, don't assume that water will come out of it in case it accidently opens
. I would much rather assume it does. It is better to be more cautious than not and unless you know for sure, err on the side of caution.
Fire suppression systems are mandated in data centers, the same as any other commercial establishment. The type selected could be wet sprinkler, dry sprinkler, or chemical. All will extinguish fires, some with more or less damage to the equipment and the occupants. All are acceptable by code. Not all carry the same level of passive risk. If that's an argument, well so be it.
that really wasn't the arguument and I agree with what you just stated.
Old 11-03-2009, 05:08 PM   #17
nap
You talking to me?
nap's Avatar
Originally Posted by DIYtestdummy View Post
And back to the topic - I pushed a button today that nobody knew what it did. I'm still waiting for something to happen!!!
the police are on the way to your house as I type this.
sounds like all is cool. I understand your reasoning. As you said, sometimes what we see as logical is not the same as maybe an engineer, customer, or inspector sees as logical.
the truth is, as maintenance stated; all are legal. some are a better idea than others.
back button not working joed Site Help and Suggestions 9 11-12-2008 01:08 AM
Pilot light button on furnace won't turn whydonchathen HVAC 5 10-06-2008 12:03 AM
Contacor button jw1 HVAC 8 06-12-2008 05:15 PM
Replacing Button for Electrical Garage Door Opener FL_Deb Electrical 6 04-22-2008 12:36 PM
Possible to remove a button on/off? Alpha Crow Electrical 2 09-27-2007 07:20 PM
