Unsafe Adapter Cord - Off Topic - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 10-03-2010, 11:01 PM   #1
WDR
unsafe adapter cord
I found this adapter on ebay, it has a 30 amp male plug with a 15 amp female plug, I would think this is unsafe. It is item #160437416168
WDR is offline   Reply With Quote
Old 10-04-2010, 07:58 AM   #2
Rewards Points: 1,418
Yes it is unsafe unless it has a built in fuse or circuit breaker for no more than 15 amps (one 15 amp female receptacle) or 20 amps (two or more female receptacles already attached).
But once in awhile someone has a need for such a gadget and will buy one without a breaker if he cannot find one with a breaker.
A gadget with two male plugs connected together is highly unsafe.
Old 10-04-2010, 08:51 AM   #3
I=E/R
a7ecorsair's Avatar
These are very common in the RV industry. When installed, you just can't use the AC.
a7ecorsair is offline   Reply With Quote
Old 10-04-2010, 05:01 PM   #4
WDR
adapter cord
Unfortunately I do believe I saw a male to male cable on a website some were now that I think about it. I will try to find it so you can see, The one thing that I found strange about all of these cords is they look factory made. I would have thought there would be regulations, esspecialy about the male to male one.I just found the male to male, also on ebay item #180566160685
Old 10-05-2010, 05:17 PM   #5
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
male-to-male cords are commonly know as "suicide cords" and "widowmakers" since if one end is plugged in, the other end is live.
the most common use i've ever heard of is for backfeeding your house electric from a generator, instead of going through a transfer switch
l don't care what the application, they are a bad idea
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 10-05-2010, 05:50 PM   #6
WDR
cord
Yes I agree that they are highly unsafe, I was concerned about the 30 to 15 amp plug but the double male plug is absurd!
Light cord to screw in socket adapter? Charger Electrical 11 05-02-2010 07:04 PM
Is my extension cord OK? MT Stringer Electrical 4 10-20-2009 08:25 AM
Ele hot water tank and welder sharing circuit wazeaz Electrical 68 03-19-2008 08:17 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
Do I have a 30 amp or 70 amp welder. And help wireing it. Tmb9862 Electrical 17 12-04-2006 10:21 PM
