Uhhhh Ohhhh - Off Topic - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 05-11-2007, 10:41 AM   #16
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
Originally Posted by AtlanticWBConst. View Post
First off.... I'd look into the actual details of this 'warranty'....
Especially who is backing the warranty and where they are likely to be in 10 years. Also, "limited warranty" is about as scary as everything else. If you are going to invest a good deal of money and you are determined not to run off screaming, which is what I would do, then I would consider having an attorney take a peak at that warranty too - especially if there is ambiguous langauge involved.
Bottom line to me is simple this - for industries like this, I typically think of pride of workmanship as the best barometer to trust people's work. In this case, I think the fact that these sloppy things were left undone for inspectors to see for anyone to see speaks volume.
J187 is offline   Reply With Quote
Old 05-13-2007, 10:14 PM   #17
Rewards Points: 1,470
I wouldn't touch this house.....
FWIW: The bricks are not under the foundation, they are on top of the foundation (typically). I wonder could there have been a change in plan for the exterior, or if this is an indicator of some other construction fault.
ktkelly is offline   Reply With Quote
Old 06-19-2007, 03:05 PM   #18
I don't know any builders that would put their name on that house. Cracks in the sheetrock on a new house are a bad bad sign. Old houses settle. New houses shouldn't.
Just my humble opinion. I would keep looking.
If it sounds too good to be true then it probably is.
"Good judgment comes from experience. Experience comes from bad judgment."
keyser soze is offline   Reply With Quote
