Table Repair Method - Off Topic - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 03-25-2009, 08:15 PM   #1
Table repair method
I have a method for repairing some inexpensive tables--I've searched high and low and have yet to find anyone else who's published this idea. So here goes.
I once was in charge of IT for a high school, which had a lab with several inexpensive, flat-pack tables. The metal legs machine-screwed into metal bases that were attached to the undersides of the tables with 1/2" wood screws. Needless to say, a few years of high-school student abuse, and the bases started coming loose.
I drilled 1/4" holes straight through the tables where the screws went, fed carriage bolts down through the table, and tightened nuts on the underside where the wood screws used to attach. Tightening the nuts pulls the carriage bolts' round heads right up to the table--the square shank bites right into the particle board. I used just the right carriage-bolt length so protruding bolts wouldn't scratch students' legs. Since doing this, the tables are stronger than ever, and the leg bases aren't coming loose anymore.
The only disadvantage? There are going to be carriage-bolt heads visible on the surface of the table, but I'll trade that any day for not having to buy new tables--and not having the tables collapse.
I did the same trick at home with two folding tables whose leg clamps popped loose: EMT clamps and carriage bolts.
mahohmei is offline   Reply With Quote
Super glaze bar table finish jlwiu1 General DIY Discussions 18 02-05-2016 04:52 PM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
Delta 10in table saw repair GillesLam Building & Construction 3 03-21-2009 05:19 PM
Need Advice for Adding Wheels to Table HandyDottie Carpentry 7 01-27-2008 08:44 PM
Question about table saws,... tribaloverkill Tools 28 04-13-2007 09:47 AM
