Suspending Model Train Tracks - Off Topic - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 06-20-2012, 11:27 AM   #1
Busy DIYer
picflight's Avatar
Rewards Points: 150
Question
Suspending model train tracks (PICS)
Looking for ideas on suspending LGB kind railway track, H0 scale, from the flat ceiling of 14' x 10' room.
I am thinking aluminum tubes as the bed, however, I have never done any sort of welding before.
What other materials I can use for the track bed and hangers?
Something like:
picflight is offline   Reply With Quote
Old 06-20-2012, 02:35 PM   #2
joed's Avatar
Rewards Points: 13,762
Use threaded rod as the hanger rods and your aluminum tubes as the base. Then only nuts and bolts are needed.
Old 06-20-2012, 04:32 PM   #3
Busy DIYer
picflight's Avatar
Rewards Points: 150
@joed, what sort of threaded rod should I use, that is what I had in mind. Have no idea where to find them.
Old 06-20-2012, 04:40 PM   #4
Old School
Willie T's Avatar
A flat road of Plexiglas or Lexan mounted off the walls on the same type of angles... strong plastic.
This is the idea: http://youtu.be/nqT_rOomd64 but without those bulky ceiling hangers.
Or something like this: http://youtu.be/CTSJPBwGJaw
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
picflight (06-20-2012)
Old 06-20-2012, 06:14 PM   #5
Busy DIYer
picflight's Avatar
Rewards Points: 150
I like the idea of plexiglass, you can see from below. I wonder how they have joined the plexiglass platform.
I like the suspended ones, not too fond of having a shelf type even though I will run it in one room near the walls.
Old 06-20-2012, 06:23 PM   #6
Busy DIYer
picflight's Avatar
Rewards Points: 150
Plexiglass is expensive:
102.40 USD 48 inch x 96 inch, I will need 10 of these.
Old 06-20-2012, 06:36 PM   #7
Busy DIYer
picflight's Avatar
Rewards Points: 150
http://youtu.be/qt367afSbwg
Old 06-23-2012, 11:03 AM   #8
AHH, SPANS!!!
Rewards Points: 1,166
the diagram looks like oak dowel rods drilled into top and bottom pieces, 1 x2. simple to make and strong enough if glued correctly and the top is toggled strongly to the ceiling...
hand drive is offline   Reply With Quote
Old 06-23-2012, 08:50 PM   #9
Too Short? Cut it Again!
Aircraft cable or stranded wire braid and ferrules?
Building a Thomas Train Bed raptor22 Carpentry 8 10-21-2012 11:19 AM
Carrier model 58STX110-22 missing parts Alashikata HVAC 0 05-15-2012 12:09 AM
Delta 10" Compound Miter Saw Model Number miamicuse Tools 1 05-09-2012 09:47 PM
Compare Carrier Model 25HNA936A003 versus Model 25HPA636 gchapman General DIY Discussions 0 11-02-2010 12:52 PM
