-   Off Topic (http://www.diychatroom.com/f39/)
-   -   Suspending model train tracks (http://www.diychatroom.com/f39/suspending-model-train-tracks-147686/)
picflight 06-20-2012 12:27 PM
Suspending model train tracks (PICS)
Looking for ideas on suspending LGB kind railway track, H0 scale, from the flat ceiling of 14' x 10' room.
I am thinking aluminum tubes as the bed, however, I have never done any sort of welding before.
What other materials I can use for the track bed and hangers?
Something like:
http://i937.photobucket.com/albums/a...Train/dual.jpg
joed 06-20-2012 03:35 PM
Use threaded rod as the hanger rods and your aluminum tubes as the base. Then only nuts and bolts are needed.
picflight 06-20-2012 05:32 PM
@joed, what sort of threaded rod should I use, that is what I had in mind. Have no idea where to find them.
Willie T 06-20-2012 05:40 PM
A flat road of Plexiglas or Lexan mounted off the walls on the same type of angles... strong plastic.
This is the idea: http://youtu.be/nqT_rOomd64 but without those bulky ceiling hangers.
Or something like this: http://youtu.be/CTSJPBwGJaw
picflight 06-20-2012 07:14 PM
I like the idea of plexiglass, you can see from below. I wonder how they have joined the plexiglass platform.
I like the suspended ones, not too fond of having a shelf type even though I will run it in one room near the walls.
picflight 06-20-2012 07:23 PM
Plexiglass is expensive:
102.40 USD 48 inch x 96 inch, I will need 10 of these. :eek:
picflight 06-20-2012 07:36 PM
http://youtu.be/qt367afSbwg
hand drive 06-23-2012 12:03 PM
the diagram looks like oak dowel rods drilled into top and bottom pieces, 1 x2. simple to make and strong enough if glued correctly and the top is toggled strongly to the ceiling...
user1007 06-23-2012 09:50 PM
Aircraft cable or stranded wire braid and ferrules?
