Sub Contracting Out A New Home? - Off Topic - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 10-15-2010, 05:59 PM   #1
Rewards Points: 18
Sub Contracting out a new home?
How much money would you save if you sub contract out your whole house yourself? I guess I am just looking for a general number. Thanks.
Insaneman1731 is offline   Reply With Quote
Old 10-15-2010, 06:01 PM   #2
jlhaslip's Avatar
Rewards Points: 392
10 per cent or around there...
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 10-15-2010, 06:28 PM   #3
Civil Engineer
Rewards Points: 4,520
If you are married and plan to act as the general contractor, I recommend you finalize the divorce papers before you start the project, because as the project progresses it will become increasingly difficult to reach an amicable split with your spouse. You need to figure the cost of marital discord into the overall cost estimate for the house.
Daniel Holzman is online now   Reply With Quote
The Following 2 Users Say Thank You to Daniel Holzman For This Useful Post:
jlhaslip (10-16-2010), jomama45 (10-17-2010)
Old 10-15-2010, 07:12 PM   #4
Rewards Points: 410
One of the problems as I see it when acting as your own GC is you probably won't get the discounts that an established GC would.
Of course then theirs the subs and which ones are reliable and do quality work on time , maybe you know the ones to use and the ones to stay away from.
A good GC will know this.
Are you going to work full time while doing this also ... good luck.
10% plus or minus around here money well spent IMO for the Right GC.
High Gear is offline   Reply With Quote
Old 10-15-2010, 07:33 PM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Check out this thread
Contractor Problems. HELP PLEASE. kwikfishron
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 10-16-2010, 02:27 PM   #6
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 690
LOL
I did this 4 years ago. My background is heavy steel construction, so light residential work is a little different for me. Nevertheless, several of the principles are the same and I moved forward. I ended up going over budget about $70k - partly because the soil was bad and had to be replaced, partly because it was an expensive design, partly because I wanted certain features regardless of the cost, and partly because it's not what I do for a living.
If you don't understand construction, you will likely cost yourself more than you can potentially save. There's a couple up around the corner from me that built their own house. They are now selling it (or trying to) for about $100,000 more than it's worth. Why? Because that's what they have in it. Shocking.
WirelessG is offline   Reply With Quote
Old 10-17-2010, 10:47 AM   #7
Chicago, IL
Michael Thomas's Avatar
Depending on the nature of the project, if you do none of the work yourself, if everything goes right: 10-20%.
If things go wrong: the problems and additional expense will seem endless.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Need advice on remodeling/renovating a prefab (mobile) home countrylifemom Remodeling 53 03-29-2015 09:15 PM
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 04:47 PM
Owning a home (not a mobile home) on leased land? Badfish740 Off Topic 11 03-30-2008 10:34 AM
Home Addition destepan Building & Construction 6 12-05-2007 01:28 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 08:43 PM
