Stupid Motorcycle.. - Off Topic - Page 4 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 10-12-2012, 06:46 PM   #46
Doc..come back...no booze. Just go see the pharmacist and if they recommend a dr then so be it. Take tylenol for pain
creeper is offline   Reply With Quote
Old 10-12-2012, 07:31 PM   #47
Preston:
Seriously...You need medical attention. You can't mess with infections
Old 10-12-2012, 08:24 PM   #48
DIY staff
Rewards Points: 7,174
Doc-- listen to creeper===and Beenthere---Get a good antibiotic burn ointment---cover the wound with the burn bandages--then a light gauze wrap---
Soak in a tub for half an hour once a day--loosen up and remove any loose scabs---wash with hydrogen peroxide---then wrap it with the burn bandage==
I was cooked up pretty good a few years back---no ugly scars and the healing went well---
Old 10-13-2012, 01:06 AM   #49
I'm Your Huckleberry
Rewards Points: 2,270
Originally Posted by creeper View Post
Preston:
Put your nurse suit on. I'll be okay then.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 10-13-2012, 06:47 AM   #50
Experienced
Jackofall1's Avatar
Doc,
You really do need to visit a doctor at least to get some proper antibiotic cream as mention in the aritcle I have attached.
Mark
HOW DO I TREAT THE BURN?
  • First degree burns. For this type of burn, you do not need a prescription cream. You also do not need to use an antibiotic cream. One of the best treatments for first degree burns is aloe vera. Buy a bottle of 100% aloe gel and apply several times a day. Be sure to buy 100% aloe. Some bottles will say, "made with pure aloe", but only contain 10% aloe. Read the ingredients. Basically, it should only read aloe on the label. You can also use the juice from the leaf of an aloe plant, if you have one.
  • Second degree burns. Treating this type of burn is more complex. You should check with your doctor about how to treat your child's second-degree burns. Here are some general guidelines that we recommend. Twice a day do the following:
    • Rinse the area with comfortable temperature water. Use a sink or bathtub faucet. The stream of water will remove germs, dead skin, and debris.
    • Air dry.
    • Apply prescription burn cream called Silvadene (the generic equivalent is silver sulfadiazine). This is an antibiotic cream that has excellent healing properties, and is an important part of the burn treatment because it's very effective at preventing infection. You need to apply it aseptically; buy a package of sterile tongue depressors to use. Use a lot of cream, as if you were icing a cake. When you change the bandage, if all the cream is worn off or soaked in, then you didn't use enough. Silvadene contains silver, and you will notice a dark "tarnish" discoloration on the bandages.
    • Cover with a bandage. Your doctor may recommend a specific type of bandage. Typically a non-stick pad is placed over the cream (one brand name is Telfa), than a gauze is taped or wrapped around the area.
    • Stretch. If the burn is on an area of the body that stretches or pulls a lot (such as the palm of the hand or palm side of the fingers), the burned skin is at risk of healing too tight. This is called a contracture. In this type of area, it is very important to stretch this skin around ten times a day for one minute.
    • Cut away the blister after the blister pops on it's own. Your doctor may cut the dead blistered skin away. This will help prevent infection and will promote healing. If you have a large blister that pops after several days, then go back to see your doctor. He or she may want to cut it away.
    • Watch for infection. Call or see your doctor if you detect any foul-smelling greenish discharge from the burn, or see an expanding area of redness around the burn.
  • Third degree burns. Because of the seriousness and potential for scarring from this type of burn, it is recommended that you go to a burn center or ER for initial treatment, and then continue your follow-up care with a burn surgeon. We cannot put any general recommendations here for this type of burn.
Old 10-15-2012, 06:27 PM   #51
Thanks.
Old 10-15-2012, 06:31 PM   #52
bbo
Should have gotten that checked out a long time ago.
bbo is offline   Reply With Quote
Old 10-15-2012, 08:07 PM   #53
looks like at this point you can't afford to not see the Dr
Old 10-15-2012, 08:44 PM   #54
JOATMON
ddawg16's Avatar
Rewards Points: 1,968
Originally Posted by beenthere View Post
That is bad. I mean the ugly leg, the burn is nothing. ROFL
If you get he burn bandages, remember that the ointment in them is flammable.
Took the words out of my mouth.....
I remember pulling a lady out of a burning house....my partner and I grabbed her arm to pull her out of the kitchen.....all we got was skin.......
Old 10-15-2012, 08:55 PM   #55
Horrific would be an understatement
Old 10-16-2012, 12:53 PM   #56
Doc,
So didja go to the clinic??
Old 10-16-2012, 02:00 PM   #57
Nope, can't afford it. It's somewhat healing, getting smaller as the edges close in. I'm aware it's going to be a scar, not my first or last I'd have to suspect.
Still hurts but it's getting better.
Thanks.
Old 10-16-2012, 02:45 PM   #58
bbo
I had that same redness on a much smaller wound. It was infected. bad. they put me on IV when I finally went into the hospital ( was travelling at the time ) spend the better part of a day there.
as I mentioned befre, this should be covered under the motorcyclist's insurance. you said it was a friend f yours bike, right?
and no such thing as can't afford to get an infection taken care of.
Old 10-16-2012, 03:56 PM   #59
I hope you heal fast. Too early to give up on something fun!
Fishinbo is offline   Reply With Quote
Old 10-20-2012, 03:23 PM   #60
Although I had a few dirt bikes in my teenage years and a few road bikes during my early 20's, I don't own a bike and have no plans of getting one either. This is what it looks like now. No doctor.
Thanks.
Stanley Powershot design is kind of stupid....dangerous actually. J187 Tools 27 06-25-2012 10:18 PM
Stupid question about air in mortar. sukhenkoi Kitchen & Bath Remodeling 1 06-07-2011 11:06 PM
Stupid Question: How to bevel cut less than 45 on a compound miter?? RickDel General DIY Discussions 2 07-31-2010 07:30 AM
Are people really this stupid?? Scuba_Dave Off Topic 7 05-21-2009 12:07 PM
Think - Am I doing something stupid? Leah Frances Safety 15 01-17-2009 06:40 AM
