Some Advice PLEASE!! - Off Topic - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 10-27-2010, 11:11 AM   #1
Some advice PLEASE!!
Well guys I am back again. We have been building our house for a few months now (contracted out) and there have been some issues along the way (expected). Crooked floors, pipes, cracked driveway, etc... We were at our house last night to see the progress and the wind was blowing pretty good (30+). Every single window facing the west (9 windows) have significant leakage. I'm talking like howling through the house. The front window looked like it was pulsating and ready to break. Most of our windows are fixed windows and are leaking air at every corner. I did some research on the windows and now I see why... Silverline is apparently not a good window (we were not given an upgrade option or told that these windows suck... or blow I guess). Is there anything we can do? It looks like we will have to put plastic over all of the west facing windows! This is a nightmare.. Thanks for reading and any advice given..
danreg99 is offline   Reply With Quote
Old 10-27-2010, 03:26 PM   #2
Rewards Points: 506
Is the air coming in from around the outer edges of the windows? Check to see what they used to fill the space around the frames.
If there's nothing there or it's just pink fiberglass insulation, you can take that out and spray some Great Stuff for Windows and Doors in there and that will prevent any air from getting through.
Make sure it's the kind that specifically says it's for windows and doors. It'll be a blue can and you can get it at any hardware.
Barb
gma2rjc is online now   Reply With Quote
Old 10-27-2010, 04:14 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 298
Hopefully you haven't paid him yet, make sure you get all done that is supposed to be done and done right before you pay him or it will be very hard to get him to correct anything.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 10-27-2010, 05:16 PM   #4
kwikfishron's Avatar
Rewards Points: 396
Is the sheetrock done yet?
Is the siding on?
Can you post some pictures?
kwikfishron is online now   Reply With Quote
Old 10-27-2010, 05:35 PM   #5
Unfortunately it is all sheetrocked, insulated and trimmed out. They didn't use any spray foam (just fiberglass insulation), The contractor says that you will have air flow on a windy day (30+ mph). Should I tell them that I would like the trim removed and spray foam installed?
Old 10-27-2010, 05:58 PM   #6
Rewards Points: 396
[quote=danreg99;524055]The contractor says that you will have air flow on a windy day (30+ mph). quote]
Thatís total BS, if the window and siding install was done properly there should be no air flow whether or not foam was used on the inside.
Old 10-27-2010, 06:47 PM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 298
[quote=kwikfishron;524069]
Amen buddy, amen!!!
Jim
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
looking for Serious advice and Help on Insulation bfan781 Building & Construction 6 05-19-2010 11:02 AM
DIY Advice Seeker - late 1970 seventies knockdown texture onegative Drywall & Plaster 1 04-22-2010 08:40 AM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 11:51 AM
I need advice on a flat roof Krissy Roofing/Siding 10 12-27-2007 01:55 PM
