Rewiring Older Home - Off Topic - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 08-23-2010, 08:22 AM   #1
Rewiring older home
How much can I expect to pay to have someone rewire my older home?
Rt2frdm is offline   Reply With Quote
Old 08-23-2010, 08:32 AM   #2
Licensed electrician
Rewards Points: 1,756
Here are some things that will affect the cost:
Size of house
House construction features
Local requirements. Some areas specify different materials or conduit.
How much damage can be done to interior finishes?
Special circuits you want or need.
Will the house still be lived in or will it be totally empty?
Age of house.
You did not specify nearly enough information. The best way is to get local estimates from licensed contractors that can see what conditions they will be working with.
Old 08-23-2010, 09:20 AM   #3
Rewiring Older Home
The house is about 1100 sq ft.
Built in the '70's
Whatever has to be done will be done. The finishes are secondary and the electrician can tell me what I need.
I don't know about the local requirements.
The house is lived in.
My problem is I can't use the dryer in the garage and my oven in the kitchen at same time. Can't use my washer, dishwasher, 0r toaster when I use my mircrowave. All flip the switches.
Old 08-23-2010, 11:16 AM   #4
The only way to know is to call a few guys and get some estimates.... there are 100s of factors that will affect the final cost.
Contact some electricians (licenced etc) and see what numbers they throw out. Make sure the number they throw out includes a permit!
DownRiverGuy is offline   Reply With Quote
Old 08-23-2010, 11:35 AM   #5
RST
DIY Homeowner
Rewards Points: 150
Sounds like you might need a service upgrade and new panel but not a full rewire. Much cheaper. Agree with the others, have some pros come out.
RST is offline   Reply With Quote
Out of Plane walls in older home! Arg! jlatulippe Remodeling 6 06-22-2010 08:15 PM
Cold Air Returns in Older Home Keegan HVAC 0 05-31-2010 09:33 AM
OLDER HOME, 100 amp box etc.. BADAZZVOLKS Electrical 2 10-29-2008 02:36 PM
Ventilation questions on older home ademero Roofing/Siding 5 10-02-2007 12:15 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
