Go Back   DIY Chatroom - DIY Home Improvement Forum > Community > Off Topic
Old 07-22-2012, 11:55 PM   #1
The retail cost of R-22 versus R-410
I had the tech out and my compressor on my FHP heat pump ac is shot. The tech said to pull it, replace it, evacuate and put 5 lbs of R-22 would be close to $1200. He said R-22 is not about $60 a pound retail. Wow.
I recall a relative had a buddy who rented a warehouse and loaded it with cans or R-22 just before the ban.
What do you guys think the retail price of R-22 versus R-410 is? Thanks.
FrankL is offline   Reply With Quote
Old 07-23-2012, 05:08 AM   #2
R-22 Locally here in SIoux Falls S.D. is $23-$30 retail to the consumer which was me. I paid that 3.5 weeks ago. DOn't know the price on 410A yet as I just had a new setup installed and that's what it has in it.
dtnel is offline   Reply With Quote
Old 07-23-2012, 05:15 AM   #3
In my area (Augusta, GA) R-22 is going for anywhere from $25 to $60 per lb. R410A is around $30 or so, for the most part.
scottmcd9999 is offline   Reply With Quote
Old 07-23-2012, 08:35 AM   #4
In my area, R22 is about $10-15 per lb, half for the 410A.
clocert is offline   Reply With Quote
Old 07-23-2012, 09:10 AM   #5
Surely that's not retail.
Old 07-23-2012, 06:17 PM   #6
An old Tradesmen
Moved to off Topic forum.
Old 07-25-2012, 02:36 AM   #7
.... I had (may still have) a leak and the HVAC guy told me he had to put 3 lbs. of R-22 in, which was $100 a lb. They put dye in, but on the next visit - 2 wks. later - he wasn't able to find the leak and only had to put in 1/2 lb., which was included in the cost of the visit.
"The problem with quotes on the Internet is that it is often difficult to verify their authenticity." - Abraham Lincoln
The economy is so bad, Exxon-Mobil laid-off 25 congressmen --- Maxine
gma2rjc is offline   Reply With Quote
Old 07-28-2012, 10:32 PM   #8
I'm Your Huckleberry
Sorry to hear that. What needs to happen is a tech needs to pull out a refrigerant leak detector and/or perform a nitrogen pressure test. Soapy water works to make the leak visible.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
gma2rjc (07-28-2012)
Old 07-29-2012, 12:10 AM   #9
Thanks Doc. I'll ask the guy when he comes back. Maybe he'll be able to figure it out.
Old 07-29-2012, 12:34 AM   #10
You're welcome. Also, insist that the tech use a refrigerant scale to keep tabs on how much refrigerant is actually added. If he doesn't have one, find another tech. Too many times without a home owner's knowledge they'll add what they might think is a pound or two or even simply say it to be able to charge it without any proof and the home owner none the wiser.
I doubt three pounds was added in the first place. Your system would've been freezing up all the way to the compressor if it was that low but that's neither here nor there at this point, you've already paid for it.
Ask for these items on the phone when you first call the next time. Fair is fair.
Thanks.
gma2rjc (07-29-2012)
Old 07-29-2012, 12:41 AM   #11
I'm an hvac tech. I pay $139 for a jug of R-410-A. I pay $389 for R-22.
My company charges $60.00 per pound. Many companies have begun charging per ounce.
Thanks.
Old 07-29-2012, 12:43 AM   #12
Thanks again Doc!
Cost to Drywall hang/finish...please read, good explanation Firehawk734 Remodeling 63 12-17-2012 10:29 PM
Cost of a small 2 story addition mattmean Building & Construction 15 08-09-2011 11:14 AM
Means/Richardson construction cost estimate lookup help please tomseeley Building & Construction 1 03-21-2011 02:36 PM
ideas on water heaters comanche General Discussion 14 03-02-2011 11:15 PM
How much does a square foot of housing cost in Albuquerque, NM? spook4563 Building & Construction 2 02-28-2011 04:04 PM
