Possible Snow, Which Vehicle Would You Drive? - Off Topic - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 02-03-2011, 07:48 AM   #1
waterman1971's Avatar
Rewards Points: 150
Possible snow, which vehicle would you drive?
We are expecting snow down in Texas.
In this location snow is somewhat of a novelty.
No off road driving, strictly a highway commute.
If one had to decide between a front wheel drive honda vs. a 2 wheel drive gmc truck.
Which vehicle would be more capable?
waterman1971 is offline   Reply With Quote
Old 02-03-2011, 08:11 AM   #2
Both but if you feel more comfortable pick truck. No real trick to driving in snow just accelerate slowly and keep your speed down. Driver from the great white north
Sellwithnic is offline   Reply With Quote
Old 02-03-2011, 09:20 AM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 142
When that happens here, I drive the one that would hurt my feelings less if I went into a ditch, or got hit!
Old 02-03-2011, 09:25 AM   #4
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
Rear wheel is more fun, but front wheel is safer and better control. I'd go with front wheel. when you need to turn a corner and some idiot is tailgating you 20 over the limit you need to be able to turn fast. Front wheel will "pull" you in better imo. Anti lock brakes are nice too.
Old 02-03-2011, 09:25 AM   #5
Rewards Points: 150
Thanks for all the replies. I guess i will go with the honda.
Old 02-03-2011, 09:27 AM   #6
Love for Construction
<*(((><'s Avatar
Front wheel drive honda, hands down
-luke-
<*(((>< is offline   Reply With Quote
Old 02-03-2011, 09:35 AM   #7
DIY staff
Rewards Points: 7,174
Have fun--Honda sounds like the safest----Beware of the idiots with the SUVs ---Mike---
Old 02-03-2011, 11:00 AM   #8
Rewards Points: 85
It's all in the tires.
FWD sucks because of weight transfer and a rear drive pick up won't have much traction, especially if it doesn't have an lsd, because the rear of the vehicle is light.
housegsx is offline   Reply With Quote
Old 02-03-2011, 01:27 PM   #9
Rewards Points: 590
If you take the truck, load up the bed with salt, kitty litter, and a shovel. That improves the traction, and if you still get stuck you have tools.
operagost is offline   Reply With Quote
The Following User Says Thank You to operagost For This Useful Post:
tcleve4911 (02-23-2011)
Old 02-03-2011, 01:32 PM   #10
Experienced
Jackofall1's Avatar
Up here the answer to safe driving in the snow, if you aren't fortunate enough to have AWD or 4WD, is front wheel drive, definately.
The weight of the drive line sitting over the drive wheels = better traction.....period!
Mark
Old 02-03-2011, 04:44 PM   #11
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 682
Just don't forget, when your FWD spins, you can no longer steer. Typically in a RWD, you will only slide the rear-end, but will still have the ability to steer your truck.
From a dead stop, it's going to be easier to get the Honda to start moving (assuming neither has TCS).
hyunelan2 is offline   Reply With Quote
Old 02-03-2011, 09:12 PM   #12
Rewards Points: 262
My 2 cents. All wheel drive is best, then 4 wheel, front wheel, rear wheel last. Weight down the truck bed as posted if you must drive it.
The most important thing though is tires with good tread. If tires are old and worn, now is the time to replace them.
Jim F is offline   Reply With Quote
Old 02-03-2011, 09:20 PM   #13
Wire Chewer
Rewards Points: 46
That's a good point. As soon as you spin, let go the gas!
Old 02-04-2011, 01:15 PM   #14
hyunelan2's Avatar
Rewards Points: 682
Not always true, especially in FWD. Here's a rather long read about FWD vs. RWD handling in tire-spin situations.
http://www.angelfire.com/biz/snwvlly/fwd.html
Old 02-23-2011, 01:35 PM   #15
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
What shape are the tires in?
What kind of tires are they?
Both vehicles described can be fantastic in the snow w/ the right tires.
Both vehicles described can be horrible in the snow w/ the wrong tires.
CoconutPete is offline   Reply With Quote
Snow Thrower or Snow Blower handy man88 Landscaping & Lawn Care 4 02-22-2011 03:50 PM
proper snow blower operation joshl Landscaping & Lawn Care 6 01-05-2011 03:57 PM
snow blower drive system bsboen General DIY Discussions 0 12-25-2009 01:31 PM
Snow Blower problem gregryan999 General DIY Discussions 2 02-14-2008 01:55 PM
Snow blower drive belt replacement help lwhiten395 General DIY Discussions 5 01-15-2008 04:14 PM
