Pool Pump - Off Topic - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 07-16-2011, 04:15 PM   #1
Pool pump
My pool pump has gone extremely loud. Could it be the bearing that's causing it?
ariel22nov is offline   Reply With Quote
Old 07-20-2011, 12:53 AM   #2
Rewards Points: 150
Yes it's a bearing. Do you have a leak at the pump?
STL B. is offline   Reply With Quote
Old 07-20-2011, 06:48 AM   #3
Thanks for your reply. No, the pump doesn't have a leak. It's only 2 yrs old. The sound is just so annoying. Any tips on how to dismantle and remove the bearing?
Old 07-20-2011, 08:03 AM   #4
Rewards Points: 150
In order to replace the bearing you have to have a puller and the right size bearing press/driver. If you have a electric motor shop near you I'd recommend taking the pump/motor to them and paying the $ to have it done. I say this because you will spent $50 on tools and parts and a repair shop will get it done for roughly the same price and return it to you the same day.
Old 07-20-2011, 08:29 AM   #5
Great! Your suggestion is well taken. Thanks and have a great day!
How to find out why your pool pump is not fully priming tripflex How To Guides 8 07-15-2015 06:15 AM
Swimming Pool Pump & Salt Water Ctlr Wiring brianr Electrical 1 06-27-2011 07:02 AM
Pool pump, cleaner, light wiring issues tulsajeep Electrical 4 06-05-2011 07:56 PM
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 05:31 PM
Pool Pump Wiring mpdive Electrical 17 06-15-2008 08:30 PM
