Pluming Hot Water Turning Cold - Help! - Off Topic - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 01-14-2010, 03:27 PM   #1
Hi,
First post, so apologies for rambling! We recently moved into the top two floors of a brownstone building and have a problem with the hot water turning cold rather quickly. Turning on the hot tap (bath or sink on either floor) results in a steady stream of hot water for up to a minute, but then it turns warm pretty quickly. The kitchen has the same problem, but it doesn't go cold quite as fast. The problem is worse on the top floor.
We had a plumber take a look and he thinks the problem may stem from cross flow coming from the washer/dryer?
Also, he tested the h/w heater which is in the basement and separate to the boiler, by feeling the pipe whilst having us run the hot water from upstairs. When the latter went cold, the h/w heater pipes were still hot. So, he thinks the h/w heater is not the problem. One last thing, when the hot water runs cold, if we turn the tap/faucet down to a slow stream, the hot water remains pretty hot.
Sorry for rambling, but just wondered if anybody else out there had any ideas as to what might be causing this?
Another plumber suggested it could be the check valve in the faucets, however, we are having the same problem with the kitchen sink (hot then cold..although it isn't quite as bad and the kitchen is on the floor below the top floor).
Any advice much appreciated
Thanks!
kissiffer4 is offline   Reply With Quote
Old 01-14-2010, 05:00 PM   #2
`Sounds like a cross connection.Try shutting the valves off under each fixture. You only need to shut off one side, hot or cold, doesn't matter. Do one fixture at a time until you find the culprit. I do not believe you had a plumber come out to look at this and they could not figure it out, very simple stuff...good luck
SuperPlumberGuy is offline   Reply With Quote
Cold water not working in washing machine. 68MHJCs Appliances 15 01-20-2009 05:18 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Cold water not working. Is there an easy fix? Shpigford Plumbing 4 12-16-2008 12:07 PM
advice on cold water pipe in basement garage area cambie Plumbing 6 10-15-2008 01:29 PM
Turning off water RachelS Plumbing 2 02-06-2008 04:02 PM
