Now That We're Done With ICE DAMS…... - Off Topic - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 03-17-2014, 04:23 PM   #1
Gymschu's Avatar
Rewards Points: 652
Now that we're done with ICE DAMS…...
Now that MOST of us are done with ice dams and the damage caused by them, well, how long til we get bombarded with the "what kind of insect is this in my kitchen" threads? Not that there is anything wrong with the topic, it's just the ebb and flow of the DIYChatroom.
The Following User Says Thank You to Gymschu For This Useful Post:
Startingover (03-17-2014)
Old 03-17-2014, 05:13 PM   #2
Rewards Points: 12
Done with ice dams?? i wishn it was -16 celsius (around 3f) today....
louis-123 is offline   Reply With Quote
The Following User Says Thank You to louis-123 For This Useful Post:
Gymschu (03-17-2014)
Old 03-17-2014, 05:49 PM   #3
Rewards Points: 13,450
My back yards flooded and my toilet will not flush.
I turned on my A/C and it's not working.
Snows melting and my sump pumps running.
Old 03-17-2014, 06:11 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,818
Home is where you hang yer hat and the weather goes with it. Coldest Winter that I can EVER remember. So cold the frost level dropped to the point where the city water line from the street to houses is freezing. Got 1000 people with frozen lines now. So much snow that if it all melts at once the Red River may flood and there will be water everywhere. That brings in a influx of our provincial bird. The Mozquitoe. As big as crows where I am.
The Following 2 Users Say Thank You to yuri For This Useful Post:
Gymschu (03-17-2014), Windows on Wash (03-19-2014)
Old 03-17-2014, 07:13 PM   #5
Rewards Points: 1,294
No real problem with ice dams this year. Frozen water pipes I had plenty of. Fortunately only one break and it was caught before it thawed. I had better luck than the city did though. Small city, about 20 square miles. Heard from a buddy in the water dept that they had over 30 water main breaks this year due to the cold. The interesting one I saw was in the road in front of one of my rentals. The frost pushed down so hard it cracked the pipe. The clay layer between it and the street surface was so frozen that the water could not get thru. It lifted the entire road up in that area about 2' until it finaly broke thru. Some of the breaks were caused by the frost pulling up on the fire hydrants. This caused the laterals feeding them to snap.
danpik is offline   Reply With Quote
The Following User Says Thank You to danpik For This Useful Post:
Old 03-17-2014, 09:40 PM   #6
concretemasonry's Avatar
Rewards Points: 2,594
yuri -
There is a lot of moisture in the snow (1'-3') cover in MN and much of it drains to the "backwards" Red River that flows north and thaws earlierfrom the south and floods the flat northern parts of NW MN & Eastern ND when it jams with ice when trying to drain north. In ND, the flood plain ner Fargo can be 25 miles wide because of the flat terrain.
It gets very interesting on the southern drainage through MN that floods and can cause up to 25' above normal water level.
There is little to do the fight Mother Nature on a big scale. I had to design some transmission towers in the Minnesota River channel near MSP and the site required a 105' high steel trussed tower that had to sit on 4-25' high concrete piers that were connected to about 80' deep pilings to get clearance over the normal river valley.
That all comes with living in the "Theater of Seasons" and rivers that run contrary to most geography and logic except when the seasons decide to change.
concretemasonry is online now   Reply With Quote
Old 03-17-2014, 11:21 PM   #7
Hvac Pro
yuri's Avatar
We had a very dry fall and all the crops got in early and apparently the soil moisture level is low. The snow we got is dry and fluffy and not wet. We have 4-6 of these amphibex floating backhoes on the Red where the ice jams the worst and breaking up channels for the last few weeks so hopefully we won't get any flooding. Winnipeg is safe due to the floodway but downstream from us can be a big problem where the floodway dumps back into the Red. The joys of living in a floodplain.
The Following User Says Thank You to yuri For This Useful Post:
Gymschu (03-19-2014)
Old 03-19-2014, 05:55 PM   #8
Rewards Points: 299
Not sure what you guys are all talking about, I found this winter to be quite pleasant!
Syberia is offline   Reply With Quote
