New Car Engine Sends Shock Waves Through Auto Industry - Off Topic - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 01-05-2012, 11:38 AM   #1
Military Mom of 4
Snav's Avatar
I searched but didn't see this already - I figured someone else would have already posted it.
http://www.weather.com/outlook/weath...92a45142dcaf80
researchers at Michigan State University have built a prototype gasoline engine that requires no transmission, crankshaft, pistons, valves, fuel compression, cooling systems or fluids. Their so-called Wave Disk Generator could greatly improve the efficiency of gas-electric hybrid automobiles and potentially decrease auto emissions up to 90 percent when compared with conventional combustion engines.
The engine has a rotor that's equipped with wave-like channels that trap and mix oxygen and fuel as the rotor spins. These central inlets are blocked off, building pressure within the chamber, causing a shock wave that ignites the compressed air and fuel to transmit energy.
The Wave Disk Generator uses 60 percent of its fuel for propulsion; standard car engines use just 15 percent. As a result, the generator is 3.5 times more fuel efficient than typical combustion engines.
I thought this sounded way cool - looking forwards to info as they progress through a functionl prototype.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 01-05-2012, 11:40 PM   #2
Rewards Points: 940
Wankel?
cleveman is offline   Reply With Quote
Old 01-06-2012, 02:07 AM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Originally Posted by cleveman
Wankel?
That's what it sounds like, a rotary engine with one of those transmissions that looks like 2 ice-cream cones with a rubber band around them (constant velocity something. Totally gear-less).
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 01-06-2012, 12:02 PM   #4
Rewards Points: 502
sounds like a cross between wankel and turbine
forresth is offline   Reply With Quote
Old 01-08-2012, 06:44 AM   #5
Rewards Points: 1,192
Felt that shock wave from the Kennworth dealers here.
bobelectric is offline   Reply With Quote
Old 01-08-2012, 05:45 PM   #6
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 72
The oil industry will buy that up in no time and we'll never hear of it again. Sad how things work. We should be running on 0 emission cars by now but political/bureaucratic BS is are stopping it.
The Following User Says Thank You to Red Squirrel For This Useful Post:
Jay 78 (01-08-2012)
Old 01-11-2012, 04:33 AM   #7
that's probable. but the us auto industry would have a good chance to get competitive again with green stuff like that!
Game of Thrones Online vs. Kultan
neinsa is offline   Reply With Quote
Old 01-12-2012, 09:13 AM   #8
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
with a cvt transmission
CoconutPete is offline   Reply With Quote
Old 01-12-2012, 09:29 AM   #9
Ironlight's Avatar
It's not anything like a wankel engine, which simply has pistons shaped like triangles which go round and round instead of up and down. It really is more like a turbine.
What's cool about this is that it is essentially purpose-built as a generator for an electric/hybrid vehicle. It's never meant to be hooked directly to the drivetrain. Pretty dang neat.
Ironlight is offline   Reply With Quote
