Ironing Center - Off Topic - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 04-10-2012, 11:03 PM   #1
Ironing Center
I have an office that also serves the purpose of an ironing room as our laundry room is extremely small. I currently have an ironing board set up as a fairly permanent fixture in that room. I am looking for a way to conceal my ironing board, iron, etc. in the room when it is not in use. Does anyone have suggestions on some type of wall unit that can be closed up when not being used to be more appealing aesthetically, but also be as functional as a normal ironing board when being used? I have tried the door hanging models, but all have been very low quality...
Cbeaty is offline   Reply With Quote
Old 04-10-2012, 11:13 PM   #2
Ravenworks's Avatar
They make wall units,etheir mounted on the wall or within,Google it because there are alot of them out there.
Ravenworks is offline   Reply With Quote
Old 04-10-2012, 11:26 PM   #3
Thanks for the reply. I have looked at several of those, but they look like a compromise functionality wise compared to a traditional ironing board (either by the length of ironing space or sturdiness). I am wondering if it would be better to try to construct something myself-not that I have the time!...
Old 04-10-2012, 11:57 PM   #4
Ravenworks's Avatar
Back in the 40's everyone had their ironing boards in the wall on their kitchen,more or less looked like a cabinet or a closet.
It would be doable .
Center bearing vs. Clear Span floors -- Span Tables WaldenL Building & Construction 2 02-24-2015 07:50 AM
Jacking up house, full length joists raised beam off of center colums. Suggestions? slowjo Building & Construction 9 09-16-2014 07:56 AM
Ductwork Around Center Beam Build HVAC 6 06-16-2009 11:56 AM
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 05:29 PM
Drilling into Center Beam leted_82 Building & Construction 2 03-06-2007 09:52 PM
