Installing Trailer Battery For Lights? - Off Topic - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 03-04-2010, 02:20 AM   #1
Installing trailer battery for lights?
Ok, I'm I hope I can get this question answered here. I have a truck with a 7-pin trailer wiring setup. I tow a horse trailer has lights in the sleeping and tack area. How can I install a battery so I don't run the truck batteries down while camping? I would eventually like to make it so the truck will charge the battery while I'm driving. But for now, I just need the install. Any info will help. TIA!
mstevens03 is offline   Reply With Quote
Old 03-05-2010, 02:55 PM   #2
Household Handyman
Rewards Points: 1,408
Maybe I can help: I have a 18' cargo/work trailer which I added three (3) interior lights within when it arrived, then did the ceiling. I put a deep-cycle marine battery up front, behind the tool boxes. The interior lights are powered from this battery, via a switch. You state you have the 7-pin trailer wiring. As far a as I know, with all 7-pin wiring, one wire is HOT (12 V) coming from your vehicle at all times. I use this HOT 12 V wire to charge both my marine battery and my trailer brake emergency break-away battery. IF your unit has electric brakes and built since 2000 (I think), then your break-away battery should be wired so as to be charged from the 7-pin hook-up. SO--do a check on all 7 pins of the vehicle (different brands use different colors) to find the constant HOT wire. Then, find the corresponding connection on your trailer connector, trace this wire (whatever color) and you have the HOT wiring. I use my 12 V system to power my 18 V battery charger going to the jobs, and to power my radio at the job. No radio-no worky. You can install separate switches for each area if needed.I do not use a battery isolator between the truck and trailer, but do between the two truck batteries. I do not leave the unit hooked up overnight-IF I can remember to unplug it, just me. I hope this helps, David
Tags
towing , trailer , trailer battery
Has anyone tried this way of fixing a dead cordless tool battery? BJLower Electrical 11 02-01-2010 02:31 PM
New Trailer service hd82 Electrical 10 04-23-2009 01:26 PM
Old UPS to car battery? pcampbell Electrical 8 01-20-2009 06:34 PM
Milwaukee v28 Battery Life r62ewa Tools 12 12-04-2008 07:58 PM
Ryobi 12v battery system JElson Tools 3 10-11-2008 10:50 PM
