I Want The Strongest Shower With Massage In The World - Off Topic - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 01-18-2012, 07:31 PM   #1
I want the strongest shower with massage in the world
I understand 2.5gpm restrictions.and built in restricters. I'll go foreign market if I need to, cut them out...whatever..what to do
Gonzozzzz is offline   Reply With Quote
Old 01-19-2012, 03:02 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 622
First off you need a 3/4 inch water line to the shower, not the 1/2 in standard.
The Following User Says Thank You to chrisn For This Useful Post:
Willie T (01-20-2012)
Old 01-19-2012, 10:19 AM   #3
Rewards Points: 400
A hot water pressure washer w/zero nozzles.
fireguy is offline   Reply With Quote
Old 01-19-2012, 10:59 AM   #4
concretemasonry's Avatar
Rewards Points: 2,654
Are you trying to remove your skin?
Dick
concretemasonry is online now   Reply With Quote
Old 01-20-2012, 10:31 AM   #5
Rewards Points: 780
"The strongest shower with massage in the world" ????
Hmmmm. Forget the wimpy shower head. Hook a fireman's hose and nozzle up on a bracket on the shower wall and turn that thing up full-blast. Do you have a fire hydrant nearby?
Just kidding, of course.
gma2rjc is offline   Reply With Quote
The Following User Says Thank You to gma2rjc For This Useful Post:
rusty baker (01-20-2012)
Old 01-20-2012, 11:13 AM   #6
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
Move to Niagara and stand under the falls.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 01-20-2012, 12:11 PM   #7
Old School
Willie T's Avatar
I'm with the OP. We have a variable massaging shower head, and it is close to useless.
Once a house is plumbed, you are out of luck on the size of the piping.
Something that somehow "turboized" the flow might make a massaging shower head worthwhile.
Willie T
Old 01-20-2012, 04:05 PM   #8
chrisn's Avatar
Rewards Points: 622
read post #2
Old 01-20-2012, 07:04 PM   #9
Rewards Points: 350
Wasn't this a Seinfeld show, where the building super puts in flow restrictors and the Seinfeld gang winds up going to some shady area to buy foreign shower heads with massive pressure? Pretty sure I've heard a tale like this before!
dougp23 is offline   Reply With Quote
The Following User Says Thank You to dougp23 For This Useful Post:
gma2rjc (01-20-2012)
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 08:03 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
