Go Back   DIY Chatroom - DIY Home Improvement Forum > Community > Off Topic
Old 08-16-2011, 05:36 PM   #1
Question
I need advice on a home project it involves PVC and copper tubing please help
I need to attach 3 pieces of 3in copper tubing to a piece of PVC pipe a cannot simply drill a hole through the copper tubing and put a screw through the copper into the PVC pipe. The copper tubing will be attached horizontally running the length of the PVC pipe. if you have any advice or tips please reply
Mufasa02 is offline   Reply With Quote
Old 08-16-2011, 06:27 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Do you have a drawing of what you are wanting to do? You could use epoxy to mount the copper on the pvc.
gregzoll is online now   Reply With Quote
Old 08-16-2011, 06:35 PM   #3
Yes I do have a very basic drawing, is there a specific type of epoxy I should use? And will the epoxy be durable enough for large amounts of use?
Old 08-16-2011, 06:50 PM   #4
gregzoll's Avatar
It depends on what this is being used for.
Old 08-16-2011, 06:56 PM   #5
I'm building a modle of a fully operational Vulcan minigun ( accept for the shooting part) so it's going to be used alot
Old 08-16-2011, 06:59 PM   #6
gregzoll's Avatar
Epoxy should work. You still will need to do some minor maintenance to keep it looking good. may want to look at some of the Steampunk forums, since they do stuff like this a lot for their characters.
Old 08-16-2011, 07:03 PM   #7
Thumbs up
Yes it's going to be a air soft minigun I expected minor maitnence for it but thank you
Old 08-16-2011, 07:04 PM   #8
gregzoll's Avatar
Now, that is something that I would like to see. The largest was a potato gun. What would be cool, is if you could design one that is a working Phalanx style gun. Would work great to stop speeders.
Old 08-16-2011, 07:08 PM   #9
Yea t would when my minigun is finished I'll probably post some pictures of it
