09-18-2010, 12:59 PM
#1
I am bidding an electrical job I need help on pricing the job
I am adding a sub panel,running about 100 feet of 14-2 wire,adding in new breakers, and chaning out 3 outlets in the house what would be a good price to charge the customer?
09-18-2010, 01:03 PM
#2
DIY'er
Are you liceansed?
If so check out the electrical talk site that is geared towards pros.
If not liceansed chances are it is illegal for you to do this work.
09-18-2010, 01:07 PM
#3
I needed help on how to price an electrical job can you help me
09-18-2010, 01:11 PM
#4
I am installing a sub panel to an add on room,running 14-2 wire about 100 ft,installing new breakers in the main panel and the sub panel,changing out outlets inside the home, can you help me find the right price and labor fee's to charge the customer.
09-18-2010, 01:13 PM
#5
Is 450 dollars to much to ask for are not enough
09-18-2010, 02:01 PM
#6
A "Handy Husband"
I hope your customer reads your posts. He needs all the help he can get.
Coastal South Carolina
09-18-2010, 02:15 PM
#7
Electrician
If you have to come onto a DIY site and ask how much to charge for this simple job, you probably shouldn't be doing this job.
By the way no electrician is going to come on here and tell you how much to charge, so no matter how many times you bump your own thread to the top you won't be getting a answer. Tell your friend to hire an electrician to do this job for them.
09-18-2010, 03:02 PM
#8
Licensed electrician
Not only that but the description of work needed is about as vague as could be. What size subpanel, 20 amp or 150? How many breakers and what sizes? AFCI or GFCI? How many receptacles?
09-18-2010, 03:13 PM
#9
Licensed Electrical Cont.
First off, this description tells us nearly nothing.
"Adding a sub-panel"? That's it? $100-$1500. How's that for an estimate?
Second off, if you have to ask this question, in such a vague cryptic way, then chances are you are not nearly qualified to do this job.
Are you licensed? Do you have insurance?
09-18-2010, 03:15 PM
#10
Besides all that, this is a duplicate thread.
09-18-2010, 03:29 PM
#11
An old Tradesmen
This, is a DIY site.
As such. this is an inappropriate question.
I moved this to the off topic forum. And will leave it open for a short while so the OP can read this.
This question is better suited to our sister sit, Contractor talk. Go there with this question, if your a contractor.
09-18-2010, 03:31 PM
#12
An old Tradesmen
Also, merged your other thread of same topic.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
