How Much Would YOU Charge? - Off Topic - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 08-14-2011, 12:07 AM   #1
how much would YOU charge?
this question is for HVAC techs who do jobs on their own time and get to charge what they believe is fair to both parties. how much would YOU charge to:
de-braze and remove indoor coil and dissasemble it outside to properly clean it with biodegradable cleaner, along with drain pan and drain lines of course
remove indoor blower motor and take it outside also to dissasemble and clean blower wheel and blower wheel assembly properly
remove fan motor panel from top of condenser to backwash condenser coil with pressurized water to get most of the dirt out
remove and install a liquid line filter drier in a easily accessible part of the liquid line
throw in a few drain tablets to prevent algae build up and replace indoor air filter
and then put everything back together and make sure that unit is working to the best of its abilities (i.e. checking pressures, temperatures, superheat, subcooling, supply and return differential, amperage @ compressor, etc.)
how much would you charge for such a service? give honest answers only please.
Frank
Final Notice is offline   Reply With Quote
Old 08-14-2011, 05:41 AM   #2
An old Tradesmen
Rewards Points: 8,168
Moved to off Topic forum.
While its an HVAC related question, its not a DIY question.
Might want to join one or both of our sister sites. Contrctortalk.com, and or hvacsite.com
Old 08-14-2011, 06:40 AM   #3
Not so new
12penny's Avatar
Rewards Points: 520
Frank...heres the formula that every contractor uses.
Labor + Materials + Overhead + Profit = Cost
12penny is offline   Reply With Quote
Checking charge using Subcooling civiltoatee HVAC 30 05-20-2011 05:32 PM
Charge line from car to trailer Scardey eCat Electrical 7 10-24-2010 10:38 PM
how much should i charge? jimmy21 Flooring 7 12-16-2008 06:39 PM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 08:13 AM
How much do I charge? canadaclub General DIY Discussions 3 11-09-2006 06:04 PM
