How Much To Drywall My Basement?? Estimate - Off Topic - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 10-23-2007, 05:07 PM   #1
How much to drywall my basement?? Estimate
How much would it costs (ROUGHLY) to drywall my basement. It's roughly a 12X20 ft room (240 sq ft). HOw much would it cost to do it myself??
bswain06 is offline   Reply With Quote
Old 10-23-2007, 08:08 PM   #2
Assuming you have 8 foot ceilings, it would cost you about $150 in drywall from Home Depot, if you only have to do the walls. (18 sheets at about $7 ea. + tax)
If you have to do the ceiling also it will cost you about another $50 for 8 additional sheets.
You need tape. That's about $5 for 300 feet of yellow mesh tape. That should be plenty.
Corner bead is about $1.55 per stick + tax.
Joint compound and topping compound is about $7 per box. You shouldnt need more than 3 boxes to to the job.
If you are going to spray on a texture you can get a bucket of pre mixed for about $13 bucks.
I'd say $250 in materials. This is assuming 8 foot ceilings and 1/2" drywall.
send_it_all is offline   Reply With Quote
Old 10-23-2007, 08:10 PM   #3
I meant to write $60 for the additional sheets for ceiling. For some reason I can't edit on this site. While I am on that subject, anyone know why it wont let me use some types of punctuation?
Old 10-23-2007, 08:35 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Materials use can increase if there are alot of corners and soffits (common in basements finishing projects). These take up more sheets, corner bead, and especially compound....
- Build Well -
Old 10-24-2007, 11:27 PM   #5
Home Improvement Guy
ron schenker's Avatar
Don't forget the drywall screws
ron schenker is offline   Reply With Quote
Old 10-25-2007, 09:26 AM   #6
yummy mummy's Avatar
Rewards Points: 1,016
........and a lot of determination............
yummy mummy is offline   Reply With Quote
Old 10-27-2007, 02:15 PM   #7
Did someone say "mesh tape"
I would never use mesh tape.......how long have you been in the business??? I have rarely ever had taping problems....with paper tape....... mesh....if you don't push mud through the tape just right...it will crack..... correct me if I am wrong....
localtradesman is offline   Reply With Quote
Old 10-27-2007, 06:47 PM   #8
I would only recommend mesh tape for "Hot-Mud" or quick dry mixes for the more experienced DIYer. Never a problem using it that way.
However, I would never recommend quick-dry mixes to a newer DIYer.
Reason being: There is too much difficulty for a new person to master the ability to mix the quick-dry proportionately correct, without lumps, without over-mixing.
Also, the quick set-up time creates difficulties for new people as well.
FWIW: We do not recommend mesh tape for ready-mix compound - ever, the compound cracks, ...we only recommend the use of paper tape.
- Build Well -
Old 10-27-2007, 07:10 PM   #9
Take it easy...It is just a little more user friendly for a diy job.
Old 10-31-2007, 11:18 PM   #10
Send a message via Skype™ to mwehnes
Mesh tape is great for repair work. However, I'd never use it for new construction.
Concerning the hot mud.. RUN! if your a first timer. Instead buy the green top (it has a green lid) USG Sheetrock Joint Compound in a 5 gallon bucket. Fantastic product, you won't be disappointed.
I also recommend spending an hour or two reading on http://www.drywallschool.com. It helped me figure out what I was doing wrong the first time.
mwehnes is offline   Reply With Quote
Old 10-07-2008, 05:43 AM   #11
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
I use Plus 3 blue lid most of the time. It's cheap. Is the green lid stuff better somehow?
Jamie
jamiedolan is offline   Reply With Quote
Old 10-07-2008, 07:53 AM   #12
Jamie
Hi,
First off, be aware that you are responding to a post that is pretty old.
Second, as far as your question regarding the Blue top or green top ready mix compound. The green top contains more moisture, and is slightly more dense, and is good for imedding paper tape, and second coating areas.
The blue top is primarily for finish coating (last coat). It is less granular in it's make up, and sands finer and smoother.
- Build Well -
Old 10-07-2008, 03:13 PM   #13
DIY'er
jamiedolan's Avatar
Originally Posted by AtlanticWBConst. View Post
Hi,
Thank You. I am going to have to learn a bit more about this in the upcoming months. My dad and I have had great success putting in many sheet of rock that is nice and smooth, great seams, no problems (mainly using plus 3, although I know my dad mixes up stuff on larger job). However I am going to have to match some of the original plaster work in my home when I re-do the soffit boxes in my kitchen...
Jamie
Drywall Estimate - ATLANTA eddle6389 Remodeling 7 02-01-2012 10:07 PM
Drywall vs. drop ceiling for basement DIY4EVER Building & Construction 23 11-15-2008 08:24 AM
Cannot get my drywall into the basement. jeremy56 Building & Construction 17 04-02-2007 05:08 PM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 09:27 AM
