How Does Electricity Meter Calculate Kwh? - Off Topic - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 09-05-2010, 09:10 PM   #16
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
do you have an electronic or electromechanical meter? If electronic, does it give you PF readings?
and you can add a contactor along with the var correction cap so the cap is not in circuit unless the heat pump is running. Not a lot more complex.
Old 09-05-2010, 11:27 PM   #17
I just have digital multimeter. I guess it's not quite relevant. I think I need to buy one. Any suggestion?
deerhunter is offline   Reply With Quote
Old 09-05-2010, 11:53 PM   #18
nap
You talking to me?
nap's Avatar
I meant the meter on your house.
Old 09-06-2010, 09:26 AM   #19
I=E/R
a7ecorsair's Avatar
How do you know that your heat pump isn't designed and built with the correction already installed? As I mentioned before, this is one step that is taken to increase the SEER.
I'm sure you've read through this on Wiki: http://en.wikipedia.org/wiki/Power_factor
Importance of power factor in distribution systems
The significance of power factor lies in the fact that utility companies supply customers with volt-amperes, but bill them for watts. Power factors below 1.0 require a utility to generate more than the minimum volt-amperes necessary to supply the real power (watts). This increases generation and transmission costs. For example, if the load power factor were as low as 0.7, the apparent power would be 1.4 times the real power used by the load. Line current in the circuit would also be 1.4 times the current required at 1.0 power factor, so the losses in the circuit would be doubled (since they are proportional to the square of the current). Alternatively all components of the system such as generators, conductors, transformers, and switchgear would be increased in size (and cost) to carry the extra current.
Utilities typically charge additional costs to customers who have a power factor below some limit, which is typically 0.9 to 0.95. Engineers are often interested in the power factor of a load as one of the factors that affect the efficiency of power transmission.
With the rising cost of energy and concerns over the efficient delivery of power, active PFC has become more common in consumer electronics.[16] Current Energy Star guidelines for computers (ENERGY STARŪ Program Requirements for Computers Version 5.0) call for a power factor of ≥ 0.9 at 100% of rated output in the PC's power supply. According to a white paper authored by Intel and the U.S. Environmental Protection Agency‎, PCs with internal power supplies will require the use of active power factor correction to meet the ENERGY STARŪ 5.0 Program Requirements for Computers.[17]
a7ecorsair is offline   Reply With Quote
how to connect from meter to 3 loads. ahill Electrical 2 07-28-2010 01:27 AM
HELP - wiring a 4 gang switch panel Tim_ Electrical 31 01-14-2010 06:27 PM
Tiny elbows on meter? pcampbell HVAC 24 10-06-2009 10:54 AM
Water meter aggravations Ultrarunner2017 Plumbing 8 03-21-2009 07:53 AM
Frozen water meter stubborn1 Plumbing 5 01-26-2009 07:35 AM
