Home Style ID ? - Off Topic - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 04-16-2010, 11:56 AM   #1
Home Style ID ?
I'm more and more interested in restoring my home to at least semi-accurate period style but I have no clue what style it actually would fall under - especially with the aluminum siding covering any details that might have been done on the original facade. I know it isnt a strict Arts & Crafts but it doesn't quite fit a Bungalow style either from what I have been able to figure out. The front porch construction is concrete, including the columns - which oddly enough have Ionic detailing.
The home was built in +\-1920, is wood framed with a front and (now) enclosed rear porch. The trim is all fairly wide (4" door / window trim) but very simple. There is very little detailing on it other than the crown at the top of the doors / windows. I do know the original owner was also the builder (and a professional builder I believe based on the sign I found while cleaning.) It is all plaster & lathe and seems very well built.
If it helps at all - I've attached a rough plan and a photo of the front. There is also some info on the neighborhood itself.
http://louisville.about.com/od/neigh...louisville.htm
http://www.louisvillestimes.com/nabes/german.phtml
Thanks!
cellophane is offline   Reply With Quote
Need advice on remodeling/renovating a prefab (mobile) home countrylifemom Remodeling 53 03-29-2015 08:15 PM
Advice on Replacing Rusted Bath Undermount Style Sink mdonovan Plumbing 12 11-09-2013 02:36 PM
Insulateing a Home Rifeman Building & Construction 9 08-31-2007 04:28 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
