Go Back   DIY Chatroom - DIY Home Improvement Forum > Community > Off Topic
Old 07-13-2010, 09:30 PM   #1
Hired a contractor- intalled windows from outside?
I know this is DIY and we would have done it ourself but maybe someone has had vinyl replacement windows installed or done it yourself.
Our contractor is installing them from the outside by taking off the wood trim and wood stops on the outside - no minimum explanding foam and says he will stuff insulation in there before putting on aluminum trim and vinyl siding.
Anyone see a problem with this?
They've had several problems squaring the windows up due to settling of this old house. And I think they've gotten lucky with the rest!
It is through a lead abatement program and I wasn't sure if this was the procedure to prevent lead from getting inside the house?
But there are enclosures you can use to contain the lead inside?
I'm confused. We've installed 4 windows ourselves and my husband does the job and does it right and well, this is very different from what he did.
If I need to move this post to a different forum please let me know!
THANKS!
ABEV is offline   Reply With Quote
Old 07-13-2010, 09:50 PM   #2
Tom Struble's Avatar
many window installers only install from the outside,aside from the lead issue,there is no inside trim disturbance and less mess in your home,good installer can do it either way successfully
Tom Struble is offline   Reply With Quote
Old 07-13-2010, 10:40 PM   #3
Moderator
I agree with Tom.
" says he will stuff insulation in there" ---- WHAT? Not fiberglass! Not stuff!
Be safe, Gary
Clothes taking longer to dry?
Old 07-13-2010, 11:01 PM   #4
Fast and easy,making money
gotboost is offline   Reply With Quote
Old 07-14-2010, 08:06 AM   #5
MJW
Sounds like all insert windows. IMO, a new construction window is MUCH better, especially since you are doing siding at the same time.
MJW is offline   Reply With Quote
Old 07-17-2010, 10:56 AM   #6
our guys did it the same way,,, MUCH faster & less cleanup inside which greatly pleased my bride, nagzilla
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Comparing Replacement Windows Amycat Windows and Doors 71 06-24-2011 12:58 PM
Replacing Vinyl Windows w/o Nailing Fin irish Building & Construction 1 06-03-2010 11:37 AM
replace anderson windows hobbyguy2002 Remodeling 13 12-06-2009 10:34 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
