Hey Ford Motor Company - Off Topic - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 05-28-2013, 06:51 PM   #16
Concrete & Masonry
Rewards Points: 576
Originally Posted by Doc Holliday View Post
In Winter in the 7.3's people use half gasoline and half diesel, burns hotter, starts better, runs better. You can not do that on any other diesel after by Ford. It will kill the truck.
Don't believe everything you read on the internet. No one burns half gasoline, you're getting confused with kerosene.............
jomama45 is offline   Reply With Quote
Old 05-28-2013, 09:57 PM   #17
I'm Your Huckleberry
Rewards Points: 2,270
No I'm not, gasoline. These are guys I know. It's a 7.3 club, Texas Chapter.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 05-28-2013, 10:03 PM   #18
but it's a thing up north in hard Winters that they do, mix 50/50 gas and diesel. it's supposed to be good for the truck. I don't have a need for it in Houston and there are countless stories of people accidentally filling up on gasoline, catching themselves and just pouring diesel on top and zero issues, more power, etc..
go ask yourself here. scroll down to the late 7.3 section and ask.
http://www.ford-trucks.com/forums/index.php
Thanks.
Old 05-28-2013, 10:10 PM   #19
Rewards Points: 254
The only thing mixing gas and diesel is good for is mechanics!
cjm94 is offline   Reply With Quote
Old 05-29-2013, 12:00 AM   #20
" Euro " electrician
frenchelectrican's Avatar
That useally can cause few issue when it was burning gazoline with diesel fuel and I have see some damage to them espcally if go over 15% gazoline level and with half and half brew useally don't run very well due it will have uneven burning and it will produce more knocking noise.
You will loose about 15 to 20% of total power level right there due the gazoline is lower BTU value.
And also it will be hard on some injector pump and related parts due the gazoline is " dry fuel " it will cause some issue with pump seal which I have see it from time to time.
Note this part not only affect Navistar engines but it will cover broad area of engines.
For me I use Jet fuel I can find it otherwise burn kenornse that will be no issue but some northen gaz station you may get lucky to find #1 ULSD if you do all by means get it for super cold weather useage.
you will not loose much power with this mix probly 10 to 15% the most but of course the fuel milage do drop a bit in super cold weather.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
cjm94 (05-29-2013)
Old 05-29-2013, 06:43 AM   #21
Concrete & Masonry
Rewards Points: 576
No need for me to ask or rely on random answers from the internet. I've plowed snow commercially here for 18 years, often with diesels, and can tell you that no one purposely runs gasoline. Lot's of folks run some kerosene though. But what do I know, I've only owned diesel trucks and equipment for 15 years..............
BTW, I've been around construction long enough to see more than one co-worker/laborer put the wrong fuel in at the pump.............
Old 05-29-2013, 06:57 AM   #22
no need for me to rely on one disgruntled diesel "expert" on the internet, either. I know what what I know from people who know the 7.3. you do not.
Thanks.
Ford Motor Company Posts Doc Holliday Off Topic 32 04-11-2013 02:24 AM
Ford SD 7.3 Diesel Mileage. Doc Holliday Automotive Repairs 68 10-04-2012 10:08 AM
Ford transit connect side door runner Twine99 Automotive Repairs 1 07-08-2011 12:28 PM
Any Ford Mustang Fans? Nathan Off Topic 9 03-18-2010 10:05 PM
Ford diesel API oil ratings Superrick Automotive Repairs 4 03-18-2010 08:13 PM
