Help Me Identify This PART - Off Topic - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Like Tree1Likes
  • 1 Post By joecaption
Old 07-23-2016, 07:11 PM   #1
Rewards Points: 4
Help me identify this PART
Hi,
I'm looking for a part like this to attach a hammock to the side of my house:
But I can't even start looking since I don't know what it's called
-Bogdan
RSMHomeOwner is offline   Reply With Quote
Old 07-23-2016, 07:19 PM   #2
Rewards Points: 284
Re: Help me identify this PART
Hitching ring
BayouRunner is online now   Reply With Quote
The Following 3 Users Say Thank You to BayouRunner For This Useful Post:
dd57chevy (07-23-2016), r0ckstarr (07-24-2016), RSMHomeOwner (07-23-2016)
Old 07-23-2016, 08:04 PM   #3
Rewards Points: 4,776
Most hardware stores will carry those.
Bud
Bud9051 is offline   Reply With Quote
Old 07-23-2016, 08:38 PM   #4
joed's Avatar
Rewards Points: 13,702
$3.48 at home depot
https://www.homedepot.ca/en/home/p.2...000772894.html
Old 07-23-2016, 09:37 PM   #5
I was thinking about that bracket and you might want something a bit stronger. Search for D ring anchors. Some will have two larger bolt holes oriented vertically so you can drive t lag bolts into a stud or other 2x material The rings should also be welded.
Bud
Old 07-23-2016, 09:49 PM   #6
Rewards Points: 14,294
No way would I be attaching a hammock to the side of a house!!.
Time to go to plan B.
Just no way it's going to be strong enough, just going to be doing damage to the side of the house.
SPS-1 likes this.
Old 07-24-2016, 01:19 AM   #7
Rewards Points: 4
Smile
Thanks everyone!
Once I knew what these are called I was able to find them on Amazon and Lowes & Home Depot!
I hear your concerns about this being not strong enough or damaging the house - I actually will be putting in 3 rings and putting the rope thru in a way that distributes the load evenly. Also the screws won't go into the house itself, which is stucco, but a thick board that is already bolted into the beams (used to support a now-removed patio cover).
Part identification for utility sink drain ejdischer Plumbing 15 03-09-2013 02:31 PM
Clicking sounds from unknown part between transformer and primary control Notsosuperman HVAC 7 03-07-2013 09:30 PM
Don't know what this part is called - Trane XL80 josemalone HVAC 4 12-01-2012 10:52 PM
Part Identification tomoni82 Landscaping & Lawn Care 4 07-25-2010 02:36 PM
Help me identify this part. NuclearKetchup Building & Construction 10 01-07-2009 06:04 PM
