Garage Foundation - Off Topic - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 07-26-2010, 09:09 AM   #1
Garage foundation
Hello again,
I am in Eastern North Carolina, my wife and I are looking into getting a home garage built. We wanted to start with getting the slab/foundation poured then work on the garage as we could. We have asked several companies for quotes with no reply once they see the site. I don't know why this is. My question is if anyone in this area could give me an estimated price for concrete and to work it. Or what could I add percentage wise to the price of concrete delivered to have it worked smooth?
Thanks so much!
Axe McGee is offline   Reply With Quote
Old 07-31-2010, 10:27 PM   #2
Concrete was the one thing that I did not do when building the garage. Contractor used charged $3000 for a 20x20 monolithic slab. He was $500 higher then the next bid but was worth it. He added fiber in the mix for additional strength along with using traditional rebar and wire mesh .
The Following User Says Thank You to Marty S. For This Useful Post:
Axe McGee (08-01-2010)
Old 08-01-2010, 01:20 PM   #3
I can probably handle most everything else about doing this project myself. It's just the concrete work could make everything go horribly wrong if done wrong. I figure I'm looking at about $5-6K. we'll see.
Old 08-01-2010, 01:33 PM   #4
Concrete & Masonry
Rewards Points: 530
What about the site makes it so complicated?
Maybe a pic or two would help figure that out.
When it comes to a grade beam/monolithic slab, I would rather do the gradign and forming myself, as it has a direct reflection on the finished product. That being said, I wouldn't discount the job much if I were only pouring it, since the odds are we would be "fixing" a few things to make it to "our" liking and standards.
Sorry to hear that you can't even get a quote back though. Have you tried following up after a week or so with the contractors?
jomama45 is offline   Reply With Quote
need to fix the foundation on this slab garage cnn7 General DIY Discussions 3 04-20-2010 06:11 PM
Replacement concrete garage floor, dowelled into foundation? Niffumdutz Building & Construction 5 02-19-2010 09:31 PM
Bad garage foundation Red Squirrel Building & Construction 1 07-17-2009 09:19 PM
Garage Foundation "Tilting?" Shane N Building & Construction 8 10-10-2008 11:13 AM
Garage Conversion: Loading Bearing Foundation wrldruler Building & Construction 3 08-26-2008 10:11 PM
