#16 | |
Xtreme DIY'r
A Few Random QuestionsQuote:
Answer....almost none....if the breaker trips they move something to another circuit No-one tests to run at 80% I have the tools to test all my appliances & devices & I never bother to check myself I had a washing machine (7a?), 7a dehumidifer, 7a sump pump & 3a mini-fridge all on the same 20a circuit It tripped the circuit once (Spring) when my wife was doing laundry, dehumdifier came on & the sump pump I ran another circuit for a new freezer & the mini-fridge But that setup existed for years And how many continous loads are there in a residential house that are not already on a dedicated citrcuit ? |
#17 |
i thought that part of the 3hr, 80% calculation was giving the wire a break so it wouldn't overheat. a 12 gauge wire is designed to take 20 amps, but 20 amps for 12 hours a day seems like you're pushing it to overheat at that point. if you're running new wire i wouldn't worry about it so much, but if it's k&t then i certainly would.
#18 |
Xtreme DIY'r
Actually K&T can carry more since the 2 wires are seperated & can cool off faster
The problem usually w/K&T is the insulation fails, or its been patched/modified incorrectly |
#19 | |
#20 | |
Xtreme DIY'r
We are talking residential - DIY And you know nothing of my background I don't know a single person besides myself that even owns a meter People load a breaker until the breaker goes off My wife has done this most of her life....she plugs her 12a vac/1650w hair dryer in anywhere...if it trips the breaker she plugs it in somewhere else You think people run around & test devices for power draw before they plug something else in ? Do you even think most homeowners have even heard of any 80% continous load NEC code ?? For that matter how many would even know what NEC stood for ? How many continous load items are in a residential setting that do not have a dedicated circuit ? |
#21 | |
#22 | |
Xtreme DIY'r
And for the 3rd time answer my question.... How many continous loads are there in a residential setting that do not already have a dedicated circuit ? Started by me ? You were the one telling people they can only load a circuit to 80 % |
#23 | |
now please go away |
#24 |
Can you explain where you are getting 12a for a 1650w hair dryer? Doing so might help explain something that has bugged me for years.
It seems that the typical modern hair dryer is rated at 1875 watts. But for a 120 volt circuit, that would require 15.6 amps. Since the amperage is greater than 15 amps, it would seem that they would require a 20 amp outlet and therefore they should have 20 amp plugs (where one blade is shaped like a sideways 'T'). But I've never seen a hair dryer with anything but a standard 15 amp plug. This has been a bit of a pet peevie of mine because our house was built (12 years ago) with only a 15 amp circuit, and we get nusiance breaker tips just because we'd to be able to have some lights on when we use a hair dryer. (I've included in my building permit for basement renovations to run an additional 20 circuit to the bathrooms so I can simply run a hair dryer without the nusiance breaker trips.) |
#25 | |
#26 | |
Xtreme DIY'r
NO NOT generally...only when the load is continous Residential lighting is NOT considered a continous load under NEC Every electric heater I have ever had installed has had a dedicated circuit Plug ins are usually rated at 1500w or less = 83.3% of a 15a circuit Do you think homeowners DO NOT plug these into a 15a circuit? Do you think they run around & unplug everything else from a 20a circuit to make sure they do not exceed 80% ?? |
#27 | ||
Xtreme DIY'r
Usually Mfg's have items that use less then a 15a circuit so that they can be used in older houses with only 15a circuits I'm not sure when the 20a bath circuit went into effect 12 years ago would be 1997/8 being built ? So...1995 code maybe ? |
#28 | ||
OK, can anyone start sighting code references to backup any of their claims? What I can find is NEC 210.23(A)(1)&(2) (1) seems to say that any single portable plug-in appliance can not exceed 80% of the circuit rating, and (2) seems to say that any single non-portable device (excluding lights) can not exceed 50% of the circuit rating if other devices (lights or recepticals) are on the same circuit. I can also find where "3 hours" is used to DEFINE a "continuous load". I can also find where NEC 210.19(A)(1) and 210.20(A) says that a branch-circuit must be sized by a combination of 100% of noncontinuous loads plus 125% of continuous loads. |
#29 |
Xtreme DIY'r
This has been beaten to death a number of times
So much so that most electricians that come on here refuse to look-up & cite the code reference again From what I can find a 20a bath circuit was required in 1999 Not sure about before that...possibly the 15a was code when your house was built non-portable - like a dishwasher Are you ignoring the rest of 210.23 ?? Re-read the very 1st paragraph |
#30 | |
Mater of fact, it looks like when I do the math, it looks like the 1900w hair dryers just about max out a 20 amp circuit based on NEC's 125% rule (1920w would exactly max it out). But yet these hair dryers are still designed to plug into a 15 amp circuit. I don't get it. |
| Display Modes | |
| Help How to Wire Bathroom "Fan Heater Light Night-light" unit, and questions | Tryvidy | Electrical | 9 | 06-18-2012 03:37 PM |
| How thick should my thinset be? | yummy mummy | Tiling, ceramics, marble | 20 | 09-28-2009 01:36 PM |
| Laminate wood floor layout questions | nathan.tran | Flooring | 4 | 08-30-2008 11:56 PM |
| Hey gang, another Neewb here! 261,483 questions to follow! | Portlandkids | Flooring | 6 | 08-30-2008 09:34 PM |
| some random, general plant questions | joeyboy | Landscaping & Lawn Care | 7 | 11-30-2007 07:34 PM |
