A Few Jokes... - Off Topic - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Like Tree2068Likes
Old 11-06-2013, 09:20 AM   #16
Rewards Points: 172
A very large old building was being torn down in Chicago, to make room for a new skyscraper.
Due to it's proximity to other buildings, it could not be imploded and had to be dismantled floor by floor. While working on the 49th floor, two construction workers found a skeleton in a small closet behind the elevator shaft.
They decided that they should call the police.
When the police arrived, they directed them to the closet and showed them the skeleton fully clothed and standing upright. They said, "This could be Jimmy Hoffa or somebody really important!"
Two days went by and the construction workers couldn't stand it anymore. They had to know who they had found. They called the police and said, "We are the two guys who found the skeleton in the closet and we want to know if it was Jimmy Hoffa or somebody important."
"Well," said the police, "it's not Jimmy Hoffa, but it was somebody important. In fact, he's famous for being undefeated in his field."
"Who was it?", asked the eager construction workers.
"The 1962 National Hide-and-Seek Champion."
gma2rjc is offline   Reply With Quote
The Following 2 Users Say Thank You to gma2rjc For This Useful Post:
beenthere (11-06-2013), rossfingal (11-07-2013)
Old 11-06-2013, 09:26 AM   #17
Rewards Points: 172
A carpenter was giving evidence about an accident he had witnessed.
The lawyer for the defendant was trying to discredit him and asked him how far away he was from the accident.
The carpenter replied, "Twenty-seven feet, six and on-half inches."
"What? How come you are so sure of that distance?" asked the lawyer.
"Well, I knew sooner or later some idiot would ask, so I measured it!" replied the carpenter.
Old 11-06-2013, 09:40 AM   #18
Rewards Points: 2,238
Ha, ha, ha!
I hope he measured it twice!
rossfingal is offline   Reply With Quote
The Following 2 Users Say Thank You to rossfingal For This Useful Post:
BigJim (11-06-2013), gma2rjc (11-06-2013)
Old 11-06-2013, 09:44 AM   #19
Rewards Points: 172
Top 20 Engineering Terminologies -
A NUMBER OF DIFFERENT APPROACHES ARE BEING TRIED = we are still clueless.
EXTENSIVE REPORT IS BEING PREPARED ON A FRESH APPROACH TO THE PROBLEM = we just hired 3 kids fresh out of college.
CLOSE PROJECT COORDINATION = we know who to blame.
MAJOR TECHNOLOGICAL BREAKTHROUGH = it works OK, but looks very hi-tech.
CUSTOMER SATISFACTION DELIVERY ASSURED = we are so far behind schedule, the customer is happy to get it delivered.
PRELIMINARY OPERATIONAL TESTS WERE INCONCLUSIVE = the stupid thing blew up when we threw the switch.
TEST RESULTS WERE EXTREMELY GRATIFYING = we are so surprised that the silly thing works.
THE ENTIRE CONCEPT WILL HAVE TO BE ABANDONED = the only person who understood the thing quit.
IT IS IN THE PROCESS = it is so wrapped up in red tape that the situation is about hopeless.
WE WILL LOOK INTO IT = forget it, we have enough problems for now.
PLEASE NOTE AND INITIAL = let's spread the responsibility for the screw up.
GIVE US THE BENEFIT OF YOUR THINKING = We'll listen to what you have to say as long as it doesn't interfere with what we've already done.
GIVE US YOUR INTERPRETATION = I can't wait to hear this junk!
SEE ME or LET'S DISCUSS = come into my office. I'm lonely.
ALL NEW = parts not interchangeable with the previous design.
RUGGED = too heavy to lift.
LIGHTWEIGHT = lighter than 'RUGGED'.
YEARS OF DEVELOPMENT = one finally worked.
ENERGY SAVINGS = achieved when the power switch is off.
LOW MAINTENANCE = impossible to fix if broken.
The Following User Says Thank You to gma2rjc For This Useful Post:
rossfingal (11-06-2013)
Old 11-06-2013, 12:00 PM   #20
custom user
Rewards Points: 150
How To Unsubscribe from a thread:
To unsubscribe from this thread you must first purchase a Craft-O-Matic
Adjustable Subscription Cancellation Unit. The unit can be obtained from
most hardware stores and dental clinics. Be sure to obtain the proper
permits to operate the unit from the Nuclear Regulatory Commission and
the Food and Drug Administration in Washington D.C. USA.
Be sure to carefully unpack the kit and place each component in its
accompanying mesh safety bag. Mount the Pershing DF4 mesinator on top of
the perforated Gerring Mach 77 refibulator and attach them using the
eight-millimeter torque fork. Be sure that the refibulator is mounted at
a 66-degree angle and properly dispersed so that it is flush with the
curved section of the Pyrex thistle tube. Place the four sections of the
triangular separation gear into the posture cylinder and lock them into
place using the band-aid adhesive strip. Insert the wiggling pin into
the wobbling hole, making sure that it seated correctly. Place the D
cell battery and the eleven 9 volt batteries in the power chamber.
The device should be calibrated before operation using the optional
digital corkscrew accessory pack prior to operation. Insert the digital
corkscrew through the electronic combustion service chamber using
caution not to touch the reinforced tungsten igniter control module and
quickly turn the inverter drive to 28.6 degrees. Turn the Craft-O-Matic
Adjustable Subscription Cancellation Unit upside down and hit the bottom
plate with a 48-ounce ball-peen hammer while shaking the unit
vigorously. Force open the door to the incineration valve compartment
and set the pressure gauge to 719 psi. Close the door and seal it shut
with duct tape. The unit should now be properly calibrated and ready to
use.
Before activating the Craft-O-Matic Adjustable Subscription Cancellation
Unit, you must first elevate it to a height of 229 feet above sea level
to insure that the unit receives the proper oxygen level and barometric
pressure. Point the aerial to 17 degrees north by northeast to within
the parameters of the Telstar GS-2 weather satellite and apply pressure
to the wing shaft on the southern most section of the modular
accelerator. Using the special ratchet adapter supplied with the unit,
rotate the heater core to the "on" position. The "on" position has been
obtained when the green light begins to flash, signifying that the red
light is about to go off. Once the red light is off, flip the toggle
switch labeled "ON/OFF" to the "ON" position and count to 47 before
logging on to the system.
Logon using your username and password and wait for the prompt. Once
prompted you must check the box with the appropriate action you wish to
take and then press the pressure release button and turn off the
compressor while turning the hand crank at 231 meters per minute. Next,
press control, alt, delete, caps lock, shift, number lock, escape and
tab simultaneously. Press enter.
You will have ten seconds to complete the procedure. If you fail to
respond in the time limit allowed, simply purchase a new Craft-O-Matic
Adjustable Subscription Cancellation Unit and start from the beginning.
Failure to comply with the unsubscribe policy will result in immediate
termination of your subscription to the thread so please follow the above
directions closely.
JasperST is offline   Reply With Quote
The Following 3 Users Say Thank You to JasperST For This Useful Post:
gma2rjc (11-06-2013), rockandroller (01-09-2016), rossfingal (11-06-2013)
Old 11-06-2013, 12:32 PM   #21
Mold!! Let's kill it!
Rewards Points: 2,012
Oh yeah. I just saw a Technical Service Bulletin on these (TSB). The new requirement is: instead of Duct Tape, you must use Moisture sensitive, double faced, urethane sealant tape.............. available in a variety of colors.
The Following 2 Users Say Thank You to Maintenance 6 For This Useful Post:
gma2rjc (11-06-2013), rossfingal (11-06-2013)
Old 11-06-2013, 02:03 PM   #22
The latest "tech"-bulletin, concerning color, suggests -
use "mauve"!
(Stay away from "puce" and "vermillion"!)
Thanks!
gma2rjc (11-07-2013), Maintenance 6 (11-07-2013)
Old 11-06-2013, 02:20 PM   #23
custom user
Rewards Points: 150
Damn government has to get involved with everything!
Old 11-06-2013, 03:28 PM   #24
Rewards Points: 172
Is that the same as 'multi-directional bonding strips", like Buzz Lightyear uses?
Old 11-07-2013, 12:01 AM   #25
mrs fix it's Avatar
A man was walking back home when he noticed a most unusual funeral procession approaching the nearby cemetery.
A long black hearse was followed by a second long black hearse about 50 feet behind. Behind the second hearse was a solitary man walking with a dog. Behind that were 200 men walking in a single file.
He respectfully approached the man walking with the dog and said, "I am so sorry for your loss, and I know now is a bad time to disturb you, but I've never seen a funeral procession like this. Whose funeral is it?"
The man replied, "Well, that first hearse is for my wife. My dog attacked and killed her."
He inquired further, "Well, who is in the second hearse?"
The man answered, "My mother-in-law. She was trying to help my wife when the dog turned on her."
After a moment of silence he asked, "Can I borrow the dog?"
The man with the dog replied,
"Get in line."
mrs fix it is offline   Reply With Quote
The Following 4 Users Say Thank You to mrs fix it For This Useful Post:
beenthere (11-07-2013), gma2rjc (11-07-2013), rossfingal (11-07-2013), TheEplumber (11-07-2013)
Old 11-07-2013, 12:10 AM   #26
Rewards Points: 172
Old 11-07-2013, 08:30 AM   #27
custom user
Rewards Points: 150
Pleasing everybody
There was an old man, a boy, and a donkey.
They were going to town and it was decided that
the boy should ride. As they went along they
passed some people who thought that it was a
shame for the boy to ride and the old man to
walk. The old man and boy decided that maybe
the critics were right, so they changed positions.
Later, they passed some more people who thought
that it was a real shame for that man to make
such a small boy walk. The two decided that maybe
they both should walk.
Soon they passed some more people who thought
that it was stupid to walk when they had a donkey
to ride. The man and the boy decided maybe the
critics were right so, they decided that they
both should ride.
They soon passed other people who thought that
it was a shame to put such a load on a poor little
animal. The old man and the boy decided that
maybe the critics were right, so they decided
to carry the donkey.
As they crossed a bridge they lost their grip
on the animal and he fell into the river and
drowned.
The moral of the story: If you try to please
everyone, you will eventually lose your ass.
The Following 4 Users Say Thank You to JasperST For This Useful Post:
gma2rjc (11-07-2013), rockandroller (01-09-2016), rossfingal (11-07-2013), Startingover (11-07-2013)
Old 11-07-2013, 08:53 AM   #28
Good one!
Truth and merriment, at the same time!
The Following User Says Thank You to rossfingal For This Useful Post:
Old 11-07-2013, 11:36 PM   #29
Rewards Points: 172
A construction worker goes to the doctor and says, "Doc, I'm constipated. Can you help me?"
The doctor examines him and after a minute says, "Lean over the table".
The construction worker leans over the table and the doctor hits him square in the butt as hard as he can with a baseball bat. Then he tells the construction worker to go in the bathroom and do his business.
The construction worker comes out a few minutes later and says, "Doc, I feel great! What can I do to keep this from happening again?"
The doctor replies, "Stop wiping with cement bags!"
rossfingal (11-08-2013)
Old 11-08-2013, 06:36 AM   #30
JOATMON
ddawg16's Avatar
Rewards Points: 792
What do you call a blonde that dies her hair brown?
Someone who want's artificial intelligence....
ddawg16 is online now   Reply With Quote
The Following 3 Users Say Thank You to ddawg16 For This Useful Post:
gma2rjc (11-08-2013), rockandroller (01-09-2016), rossfingal (11-08-2013)
