Yea, these guys were a drywall only sub. Most of their work, I gathered, was with GCs and builders, not home owners directly. When there is a GC involved they usually provide things like dumpsters. Also, when i built my house I used a builder. His drywall sub left the dust behind as well. the GC (or another sub) did the clean-up before painting and before carpet, etc. I think thats likely standard practice in my area.
Anyway, I'm not complaining, I just wanted to provide some context for the price I paid for this particular job so an apples to apples comparison of costs could be made. I would expect to pay a little more if the concrete floor of my basement (where the DW job was) was left completely moppped, the scraps hauled away, and a 100% flawless finish was achieved.
They did not get a A in finishing because I needed to use 'medium' sized outlet covers versus the standard small ones (rotary tools leave a larger gap), one seam on an odd angled wall could have used a wider joint (only I will notice), and one corner of a soffit was a little off with a bit of corner bead showing. Maybe I'm too picky. I was able to fix the soffit and use the slightly larger outlet plates. I am living with the one joint that should have been feathered out farther.
That particular joint was where a wall jogged out to accommodate a sewer drain, the wall looks like this
Code:
_____
\_____________
The wall in the middle was about 30" wide, the outside corner was only feathered back maybe 14" or so, same with the inside corner. This left a slight depression in the middle of that 30" wall. Ideally this would have then been skimmed with a coat of mud in the middle. I didn't notice until everything was painted and the trim was going on. I was able to get the trim tight to the wall and its not noticeable so I'm not going to fix it. Well, its noticeable to me but not anyone else.
