Discussion On Using Red As A Ground - Off Topic - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Closed Thread
Old 06-23-2010, 07:49 PM   #16
and no chance someone could be holding something grounded while this is going on ?
What electronics might be messed up by that instant of power on the ground ?
Scuba_Dave is offline
Old 06-23-2010, 08:39 PM   #17
Unhappy
xxPaul CPxx; (Poster # 75) The (possible) scenario could be as you quoted me and Scuba Dave. the point is, that somewhere down the line, with a Second or third owner of the house, would assume (which is a dangerous thing in itself) that, since this is a colored wire, other than Green or White, it should be used as a current carrying wire, and will energize it, while being connected to ground. I don't think it is much fun to watch the flash that will occur.!
spark plug is offline
Old 06-23-2010, 11:18 PM   #18
Totally screwed together
Well, someone COULD be holding something grounded... but it wouldn't matter. The circuit ISN'T through any other ground connection, it's through the fully insulated wire directly back to the ground bus.
Does your TV blow up when you trip a breaker in the garage? Or what about dropping a hair dryer into the bathtub... oops! But everything else is OK because the ground did it's job, drawing the current directly back to the ground bus at the service panel.
xxPaulCPxx is offline
Old 06-23-2010, 11:21 PM   #19
Originally Posted by spark plug View Post
...since this is a colored wire, other than Green or White, it should be used as a current carrying wire, and will energize it, while being connected to ground...
Keep going, describe how that would happen? Think this out - what gets connected where?
Old 06-24-2010, 09:35 AM   #20
Think what out ?
Its the code...its the way to wire it so that future peopl woirking on the electric wiring can expect the SAME exact wiring as what the code outlines
Period
This forum is for DIY
Not discussing why you should be able to wire any way you want because it really doesn't matter
Closed Thread
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 04:55 PM
Lost my Ground jodywoj Electrical 10 12-20-2009 06:37 PM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 03:26 PM
12v DC ground to chassis ground of a 120V appliance? pcampbell Electrical 12 02-17-2009 09:24 PM
Grounding VS Bonding BillyD Electrical 24 06-22-2008 12:14 PM
