Go Back   DIY Chatroom - DIY Home Improvement Forum > Community > Off Topic
Old 06-29-2010, 06:45 PM   #1
disconnect ac
I am currently renovating my basement and my lines for the ac do not run high enough so i can put a t-bar ceiling in the basement. I am also regrading my lot so I thought this would be a good time to put the unit on a bracket or just place it on a pad. How much would the disconnect and reconnect cost. Please say where you live and what the the hour wage is for the journeyman. Any info would be appreticated.
creamcorn is offline   Reply With Quote
Old 06-29-2010, 07:12 PM   #2
An old Tradesmen
disconnect ac
This is not completely in theme with DIY. So moved to Off Topic forum.
Old 06-29-2010, 08:32 PM   #3
disconnect ac
Looking at $500ish here to disconnect, move, reconnect and vacuum pump existing freon lines. Shop rates are $84 an hour per lead man and $65 for a helper.
30A Air Conditioner Disconnect JPWMU Electrical 6 04-19-2010 04:55 PM
Main disconnect neutral wiring Daniel Holzman Electrical 5 10-04-2009 02:36 PM
Wiring AC unit through 20A Disconnect whirly Electrical 5 04-26-2009 10:40 PM
Main disconnect box before service panel Cellomangler Electrical 4 02-04-2008 08:43 AM
fused disconnect and/or GFCI ? pchiz Electrical 8 12-21-2007 11:02 AM
