Covering Cables And Phone Lines - Off Topic - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 08-01-2006, 11:30 PM   #1
Covering Cables and Phone Lines
I just installed additional phone lines and cable tv cables to extra rooms and am looking for any ideas to cover the exposed cabling on the exterior of my residence..........
shawn ferris is offline   Reply With Quote
Old 02-13-2007, 05:11 PM   #2
daman3178's Avatar
Not sure of anything that will hide them that you can put on beside paint. Many people paint right over them making them the same color as the house. It does hide them and unless you are by them you really can't see them. Hope that helps!!
daman3178 is offline   Reply With Quote
Old 02-15-2007, 07:37 PM   #3
Not knowing how you routed them and what the outside of your home is makes it difficult to come up with any ideas or suggestions for your particular case. Is the wiring on wood yes it could be painted or trim could be used to cover it. I have seen cases were with vinyl siding it was stuck under a panel I guess this could be done with aluminum siding too. I am not sure how I would try and hid wiring on brick or stone.
Most case the outside wiring on homes do not really seem to be noticed by most onlookers unless it is done sloppy. best way to make them unnoticed is run them neatly were they may be seen.
Mgmopar
MgMopar is offline   Reply With Quote
