Go Back   DIY Chatroom - DIY Home Improvement Forum > Community > Off Topic
Old 06-03-2010, 10:00 PM   #1
Cost of installing potlights
I know electricians charge per recessed light, i know with the attic above its more expensive. Im just curious how much would it cost an electrician to install 10 recessed lights with the attic above. I hear they charge $50-$100 a light or something like that. Im just wondering what would be a rough estimate so i can budget for it.
latinomusician is offline   Reply With Quote
Old 06-04-2010, 06:35 AM   #2
Super Moderator
That is a tough question. Actually ,with an open attic above--the work is easier than when installing on a first floor,with a second floor above.
Any electrician bidding on the work will have to come to your place and see what challenges await.
Things that affect cost---Your location--Labor is cheaper in Arkansas than in New York city.
Local codes--My area requires conduit--Much more expensive than Romex.
Plaster or drywall?
Will a new circuit from the breaker box be required?
Dimmer switch or regular?
Is drywall or plaster repair(and painting) included in the bid?
If you can answer all of these questions--no one here will be able to give you a guess--Still need to see the job.---Mike---
Cost to Drywall hang/finish...please read, good explanation Firehawk734 Remodeling 63 12-17-2012 10:29 PM
(true) Replacement window cost windowpoor Remodeling 20 10-05-2011 11:20 AM
Installing saddle valve on hot water pipe Dbizot Plumbing 6 01-14-2010 12:11 PM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 09:26 PM
Cost of installing Attic Furnace in new construction marejw HVAC 3 01-11-2008 05:00 PM
