Controlling people quiz
Published originally in the 15th century, Niccolo Machiavelli’s book, THE PRINCE, discusses the use of
manipulation and power as a technique for controlling other people.
Are you Machiavellian?
THE TERM “Machiavellian” has come to be used
to describe devious, manipulative people who
are motivated only by their own self-interest.
How Machiavellian are you? This test may help
you find out. Respond to each statement below
by using the following scale:
I = Disagree strongly
2 = Disagree mildly
3 = Neutral; no opinion
4 = Agree mildly
5 = Agree strongly
ONE: the best way to handle people is to tell
them what they want to hear.
TWO: when you ask someone to do
something, it’s better to give the real reasons than
reasons that might carry more weight.
THREE: anyone who trusts anyone else is
asking for trouble
FOUR: it’s hard to get ahead without cutting
corners a little.
FIVE: it’s safest to assume that everyone has
a vicious streak that will come out if given the
opportunity.
SIX: you should act only when your action is
morally right.
SEVEN: most people are basically good and
kind.
EIGHT: there is no excuse for lying.
NINE: most people get over more easily the
death of a parent than the loss of a property.
TEN: most people won’t work hard unless
they’re forced to.
Scoring: for items 2, 6, 7, and 8, reverse your
score so that 5 becomes 1, 4 becomes 2, and so on.
Then add up all ten numbers for your total score.
A score of 25 is average. A higher score, 38 for
example, would classify you as High Mach.
A significantly lower score makes you a Low
Mach. ■
Willie T
