Contractors Procedure For Quoting - Off Topic - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 06-09-2010, 10:56 PM   #1
Contractors Procedure for Quoting
What is a typical procedure that hvac contractors go through for quoting?
I had a couple guys show up to quote for replacing furnace & ductwork. No measurements were taken, no questions about wall/window insulation. Just gave me a few options of furnaces and counted the number of heat registers needed.
I expected at least rough measurements or else how would you properly size & price out the furnace & ducts?
acerunner is offline   Reply With Quote
Old 06-09-2010, 11:38 PM   #2
An old Tradesmen
Rewards Points: 6,588
You've seen/called the rule of thumb guys.
Screen contractors over the phone. If they don't do load calcs. Tell thanks. And keep calling.
It can be difficult to find companies in some areas that do load calcs.
Old 06-14-2010, 03:33 PM   #3
Is there a newer/better rule of thumb than the 40btu rule? I wanna know if a contractor come back with a number and tell me if was a load calc, I can confirm by comparing to an approx btu I expected.
Also is there a rule of thumb for sizing a main trunk? One contractor told me approx the cross-sectional area of a 6" diameter pipe per room/heat register.
Old 06-14-2010, 04:20 PM   #4
An old Tradesmen
Nope. All of that is garbage.
Take a garden hose. Connect it to your outdoor faucet. Run it straight out. Open the faucet wide open. See how long it takes to fill a 5 gallon bucket.
Now wrap that hose in a tight circle. And see how much longer it takes to fill a 5 gallon bucket.
Turns bends all add resistance to air flow. A 6" pipe that is straight and short. Flows more air then a 6" pipe that is 10 foot longer, and has 2- 90į ells in it.
You can do your own load calc.
http://hvaccomputer.com/talkref.asp
It well worth the 49 dollar fee. And will save more then it cost on the upfront cost of the equipment alone.
Choosing a contractor Grumpy Remodeling 7 04-28-2011 08:29 AM
Sanyo mini-split install air purging procedure. s34n HVAC 3 06-09-2009 07:24 PM
Contractors Talk - Anyone a member Rivethead General DIY Discussions 4 01-29-2009 07:20 AM
Trustworthy Contractors? klum00 Remodeling 15 07-09-2007 07:22 PM
General contractors license. raymond_anthony Building & Construction 5 08-20-2006 05:07 AM
