Originally Posted by collins1193
Do you know how many inspections are needed in new construction for electrical from start to finish to be done by the inspector?
Useally 2 one at rough in and one at final { trim up } and the inspectors will use the most recent NEC code plus other codes if need to depending on the inspector itself if qualifed to cover other areas { I am sure most will be doing like that unless you have delicated inspector aka electrical inspector , plumming inspector etc etc }
It the same way with remodeling too so there is not much diffrence there and a tip to ya anytime the wall is open up to bare stud then the new modern codes do kick in and no grandfather clause will kick in at all.
{ building structure it will depending on the set up and what the inspector have to say }
Merci.
Marc
