Capacitors - Off Topic - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 08-11-2010, 02:52 PM   #1
Capacitors
Hi, I just started tech school for electrician and I was wondering exactly what a capacitor is and does. thanks
Kyle Reed
ReedELC101 is offline   Reply With Quote
Old 08-11-2010, 03:01 PM   #2
Just call me Andrew
Rewards Points: 1,020
I think this link might help you...
http://tinyurl.com/2c88xws
Andrew
secutanudu is offline   Reply With Quote
Old 08-11-2010, 03:12 PM   #3
Electrician
Proby's Avatar
Kyle Reed
Where are you located?
What type of school did you join (associated with any program)?
What type of electrician do you want to be?
As for the capacitor, there is nothing I can tell you that would be better than the link above.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-11-2010, 04:33 PM   #4
Electronics Geek
static_engineer's Avatar
The short answer is that capacitors are like batteries in that they store a charge.
Depending on the type of capacitor they could be used for varying reasons. Sometimes to store a charge like in a high power car audio application the capacitor will take up the "slack" when the battery can't provide enough power. Some smaller tantalum caps are used on DC power supplies to filter out high frequency noise.
They also act just the opposite as resistors because resistors in series add their value, and subtract total resistance in parallel, Capacitors subtract total capacitance in series and add capacitance in parallel.
First one I can answer!!! Woo Hoo!! An electronics degree pays off!
static_engineer is offline   Reply With Quote
Old 08-11-2010, 04:35 PM   #5
Electronics Geek
Doh!! I didn't see this or the previous, I just replied to the OP. Sorry.
Old 08-11-2010, 07:36 PM   #6
Extra credit question:
What happens if
you put a perfect short circuit across
an ideal capacitor
that is charged?
Old 08-11-2010, 07:45 PM   #7
Electrician
Proby's Avatar
What happens if
an ideal capacitor
that is charged?
The Earth collapses into itself.
Old 08-11-2010, 07:56 PM   #8
kwikfishron's Avatar
Rewards Points: 172
My electronics teacher in HS had a some sort of military capacitor the size of a 5 gal. metal gas can.
In class he charged it up and shorted it out with about a 2” thick phone book in between. WOW, a grapefruit size hole in the book and ears were ringing.
kwikfishron is online now   Reply With Quote
Old 08-11-2010, 08:03 PM   #9
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 54
What happens if
an ideal capacitor
that is charged?
If you use a flux cable, you create a flux capacitor. Only works with 3 way capacitors. These normally only work with extremely high voltages such as lightning. You can also buy Mr. Fusion home energy generators to produce the required power.
Once powered and interfaced with a time circuit, you can travel through time with it.
Old 08-11-2010, 08:31 PM   #10
Rewards Points: 172
Isnít there a car that runs on that power?
Old 08-11-2010, 08:56 PM   #11
Wire Chewer
Rewards Points: 54
Yep, the Delorean.
Actually, I badly want one of those cars one day. Would be so fun to drive that around.
Old 08-12-2010, 11:53 AM   #12
Already tried it in northern NJ.
It didn't work.
But there was a sinkhole in Passaic, I think.
Wishing people dead works slightly better.
Old 08-12-2010, 01:51 PM   #13
Rewards Points: 150
It didn't work.
Thought that was more out towards Ringwood or Wayne, where the old Ford Paint landfill was.
TJ_in_IL is offline   Reply With Quote
Old 08-13-2010, 05:09 PM   #14
Rewards Points: 2,634
What happens if you take an old vacuum tube radio, and decide to strip insulation off a wire to tube filter capaciters, with your teeth ?
Answer:
-You really learn about capacitors. ( you also learn how to fly )
SPS-1 is offline   Reply With Quote
Old 08-13-2010, 05:13 PM   #15
http://www.epa.gov/region2/superfund...ood/index.html
and here I thought that NJ, and its residents, were as pure as New York snow.
The answer, Mr. Reed, is that infinite current flows for zero time and the energy stored in the cap is dissipated in this zero time interval as a burst of radio frequency energy at all frequencies.
BTW, 'infinity' times 'zero' is 'indeterminate'.
Air Compressor blowing start capacitors? BBC3 Electrical 9 04-28-2013 12:34 PM
Capacitors and Contactors falconbrother HVAC 16 06-25-2010 02:57 AM
Capacitors berr3555 HVAC 2 02-07-2010 06:27 PM
Replacing logitech z5500 capacitors. rgsgww Home Theater 0 04-08-2009 07:30 PM
Orange stuff on capacitors? Speakersrock Electrical 17 05-18-2008 03:58 PM
