Go Back   DIY Chatroom - DIY Home Improvement Forum > Community > Off Topic
Old 06-13-2011, 09:08 AM   #1
Can I remove rust from this box?..
...that is, without making lots of holes in the box...
My neighbor threw away this old milk box. I have no use for it and so similar ones being sold on eBay, so I want to try my luck too. However, I am not sure anyone will buy this box with so much rust on it. There are no holes in the box, at least not yet. The question is: is there a way of removing the rust from the lid and the walls without completely destroying the box? I don't think a mechanical approach (sanding) will work. Any appropriate chemicals?
Thanks much!
ilyaz is offline   Reply With Quote
Old 06-13-2011, 09:16 AM   #2
Wire Chewer
Red Squirrel's Avatar
How think is the metal? I think sanding could at least help. Don't do too much to it, that looks like a vintage piece. May be able to sell that way.
Old 06-13-2011, 10:33 AM   #3
Nice find! With something like that, I would most likely clean it up a bit, and find a use for it on or near a work bench, or other place in my shop, probably just to store certain items. What a great conversation piece! Regardless though, the farthest that I would go would be to pick a small spot on or near the bottom, and try lightly sanding it with a very fine steel wool, and if I did not see results within 5-10 minutes, I would stop. I would never consider blasting or using chemical on something like that. Keep in mind that the beauty is in the eye of the beholder, and there are few of those still in pristine condition, so most people would expect some rust, and it is very possible that any failed attempts at restoration would decrease the value in the eyes of a potential buyer. Again though, that would not be a concern, in my opinion, because I would not let go of it.
Old 06-13-2011, 10:38 AM   #4
I don't have any steel wool but I do have sandpaper of various grits from 60 to 400 and maybe even 600. What grit should I use?
I brought home another vintage piece of "furniture": a 1951 GE television. It sits proudly in my living room next to the TV we watch. Unfortunately, the only type of conversation it had generated so far was my wife asking me when I am going to throw that old junk away.
Old 06-13-2011, 03:54 PM   #5
Pro Flooring Installer
rusty baker's Avatar
If you are selling it, try as is. Most antiques are more valuable if left alone. You may ruin all value by removing the patina.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
drtbk4ever (06-13-2011)
Remove old light fixture (hanging) dj928 Electrical 9 12-02-2009 12:42 PM
Removing rust from tools Colby Building & Construction 12 11-16-2009 09:22 PM
How to remove Built-in Electric Fireplace Almighty Building & Construction 1 11-12-2009 06:18 PM
Cannot remove haze from tile grout Woody36 Flooring 1 10-12-2009 09:54 PM
remove rust cast iron tub workingirl General Discussion 13 08-23-2008 03:41 PM
