Burning Telephone Poles & Railroad Tries ? - Off Topic - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Old 09-29-2010, 12:14 PM   #1
Burning telephone poles & railroad tries ?
I was under the impression that these were not supposed to be burned
Due to chemical treatments in the wood
But they just had a show on TV where they grind the stuff up & burn it
Its burned to produce electricity
So homeowners can't....but a business can ?
Old 09-29-2010, 12:37 PM   #2
fabrk8r
fabrk8r's Avatar
I always thought the reason homeowners shouldn't burn telephone poles and railroad ties was due to the creosote. Residential chimneys have enough problems with creosote buildup.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 09-29-2010, 03:42 PM   #3
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
i know creoste burns REALLY hot, so maybe it has something to do with residential fireplaces not burning hot enough, or being able to handle the extreme heat. The fumes have to be hazardous as well, maybe these commercial furnaces they burn them in have scrubbers to clean the exhaust, or burn hot enough to burn off the chemicals.
i wouldn't burn them in my fireplace, that much i know
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 09-30-2010, 04:32 PM   #4
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
The rules have got to be different also. Some concrete plants make energy by burning chopped up used tires. Try getting away with that in your backyard...
CoconutPete is offline   Reply With Quote
Old 09-30-2010, 06:10 PM   #5
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 72
I've burned PT before which is not exactly the same but same idea - not suppose to burn. I find it gives a better taste to marshmallows when roasting them over the camp fire. :D
Red Squirrel is online now   Reply With Quote
Old 09-30-2010, 06:11 PM   #6
kwikfishron's Avatar
Rewards Points: 194
Where do they do that at?
kwikfishron is offline   Reply With Quote
Old 09-30-2010, 06:59 PM   #7
No Hacks Allowed!
Fireplace creosote is not the same as the extremely poisonous wood preservative used to preserve such wood products as railroad cross ties and telephone/electric poles.
Fireplace creosote buildup is caused by plant oils (phenols) in the fireplace wood that are burned (combusted) at too low a temperature. As the wood smoke cools and rises up the chimney/flue, the volatile phenol compounds condense out of the smoke and adhere to the inside surface of the chimney. This continuous buildup of unburned smoke compounds is called fireplace creosote.
The toxic, carcinogenic wood preservative, creosote, is manufactured from coal tar.
NoHax is offline   Reply With Quote
Old 10-01-2010, 10:07 AM   #8
Rewards Points: 504
I don't know but they showed the whole process on "Dirty Jobs". Mike had the pleasure of finding the tires which had been illegally dumped out in the woods, loading them in the truck, hauling them to the facility, clean them, load them into the chopper and then ship them off to the concrete plant
Old 10-01-2010, 03:50 PM   #9
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
I've heard of that before. I think they run the emissions through a scrubber.
WirelessG is offline   Reply With Quote
Old 10-01-2010, 04:01 PM   #10
Civil Engineer
Rewards Points: 4,568
Any commercial power plant is subject to EPA emissions standards. That means they either have a scrubber, or inject special chemicals, into the mix to minimize emissions. Depending on the age and type of railroad tie, they may be treated with anything from phenol to creosote to arsenic compounds. Similarly, pressure treated wood may have metals like arsenic, copper and chromium in it, phenols, alkalis etc. Since there is no scrubber in your fireplace, by burning treated wood you are putting toxic chemicals straight into the air. Burning them hot does not cure the problem, it simply oxidizes the metal, which goes up into the air entrained on particles.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
jlhaslip (10-04-2010)
Old 10-01-2010, 06:52 PM   #11
concretemasonry's Avatar
Rewards Points: 2,578
Red squirrel -
I would not go heavy on the marshmallows. I know of a family of 6 that all have severe permanent brain damage from being in a house that burned treated wood scraps for fuel. It seemed to burn well and there was no odor, but the damage was cumulative.
If everything is perfect, it may be acceptable, but few residential applications are not perfect and there is no monitoring and sampling, pre-treatment or maintenance programs.
Dick
Dick
concretemasonry is offline   Reply With Quote
Old 10-02-2010, 10:11 AM   #12
WirelessG's Avatar
Rewards Points: 698
Originally Posted by concretemasonry View Post
Red squirrel -
Dick
That's horrible.
Old 10-04-2010, 06:35 PM   #13
this is what i thought as well. these things are seriously amazing. a few hundred miles east of where i live the army was burning VX gas in these super heat chambers that went through a scrubber and were vented off. the epa was constantly around that place and found no traces of anything.
racebum is offline   Reply With Quote
Old 10-04-2010, 06:49 PM   #14
Wire Chewer
Rewards Points: 72
Red squirrel -
Dick
Dick
Ouch. Was kidding though, well I think I tried it like once, then realized it was probably a bad idea. We had some PT lumber, a broken chair, and a bunch of other crap burning. When the flames are turning weird colors like green, blue and purple, it's best to not be cooking anything on it.
Is new PT lumber still that dangerous? It does seem kinda bad from an environmental point of view that they used such dangerous chemicals.
Old 10-05-2010, 08:50 AM   #15
Rewards Points: 504
Red squirrel -
People will burn anything... Reminds me of friends of ours. They went to a cookout and thought the flames looked funny colors. They asked the H.O. where the wood was from and it turned out to be the old floor
They ate a lot of chips n' salsa that night.....
Central air burning smell intermittent boku HVAC 7 07-14-2010 10:23 PM
Railroad rails....to catch trees. Southengineer General DIY Discussions 19 09-01-2009 03:09 PM
Testing Home Telephone Line kirridam Electrical 4 08-02-2009 08:39 PM
Odd subject: Bumpers for utility poles? jaes General DIY Discussions 7 08-19-2008 02:03 PM
Burning Bush problems/questions sk8z Landscaping & Lawn Care 1 02-14-2008 01:28 PM
