Go Back   DIY Chatroom - DIY Home Improvement Forum > Community > Off Topic
Old 05-24-2010, 01:33 PM   #1
Building in a loft space
I am moving into a loft and we are aloud to build in it, and the way the room is set up, a second floor can be added. This second floor only needs to be a floor with maybe one wall. It does not need any plumbing but might need some electrical work done to add a light or outlets. What are my options? Below are pictures of the space. The second floor would be used as is for a bedroom area and storage.
http://i183.photobucket.com/albums/x...e/IMG_0596.jpg
http://i183.photobucket.com/albums/x...e/IMG_0597.jpg
http://i183.photobucket.com/albums/x...e/IMG_0598.jpg
http://i183.photobucket.com/albums/x...e/IMG_0599.jpg
also i am looking for someone in the Los Angeles area to build it for me or give me an idea on cost. any help would be great thank you all.
sgorel is offline   Reply With Quote
Old 05-24-2010, 02:45 PM   #2
jlhaslip's Avatar
It doesn't look tall enough with the ceiling having all that pipe work and the waffle-style concrete work.
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 05-24-2010, 02:48 PM   #3
its 15 feet and the space under the new floor for the second level does not need to be that big, the only thing going under there is a flat screen and a coffee table. but you dont think i can add a second level just for a bed?
Old 05-24-2010, 06:50 PM   #4
Xtreme DIY'r
15', you need 8' for the 1st floor
Then probably 10" for the floor
That doesn't leave enough height to build a room
Check with your local building Dept
They will have the final say
Moved to Off Topic since not DIY
Progress on Storage building, more slab questions. J S Machine Building & Construction 18 05-07-2010 08:30 AM
Building a Workbench - Is this design strong enough? stubits Carpentry 3 03-12-2010 09:57 AM
Questions on Building apartment On top of existing detached garage nsxman2001 Building & Construction 4 12-16-2008 05:36 PM
Can you enclose a loft space somehow? goldie615 Remodeling 14 07-01-2008 10:02 AM
Building a Desk under stairs kelrock Carpentry 9 03-18-2008 08:24 AM
